#include <SPI.h> // incluye libreria bus SPI
#include <MFRC522.h> // incluye libreria especifica para MFRC522
#include <SD.h> // for the SD card
#include <RTClib.h> // for the RTC
//#include <LiquidCrystal_I2C.h> //Downlaod the library: i2c Liquid crystal library for Arduino
//LiquidCrystal_I2C lcd(0x27,16,2);
#define RST_PIN 9 // constante para referenciar pin de reset
#define SS_PIN 10 // constante para referenciar pin de slave select
MFRC522 mfrc522(SS_PIN, RST_PIN); // crea objeto mfrc522 enviando pines de slave select y reset
#define CS_SD 4
#define buzzer 3
#define ledrojo A0
#define ledverde A2
#define ledazul A3
#define rele 5
File myFile;
RTC_DS3231 rtc; // crea objeto del tipo RTC_DS3231
const byte Usuario[20][4] ={
{0xCD, 0x7A, 0xD8, 0x01},
{0x06, 0x3B, 0xEE, 0xF9},
{0x79, 0xAB, 0xFC, 0x5C},
{0x2B, 0x1D, 0x31, 0x09},
{0x66, 0xD8, 0xDD, 0xF9},
{0x96, 0x0A, 0xBB, 0xEF}, //Prof. Jesus Tomases
{0xE8, 0xCC, 0x58, 0x0D},
{0xC3, 0x5E, 0xEF, 0xB6},
{0x00, 0x00, 0x00, 0x00},
byte LecturaUID[4]; // crea array para almacenar el UID leido
String Docente;
const char docente_1[] PROGMEM = "Prof. Jorge Royero";
const char docente_2[] PROGMEM = "Prof. Albey Mejia";
const char docente_3[] PROGMEM = "Prof. Selfy De Los Reyes";
const char docente_4[] PROGMEM = "Prof. Giovany Peña";
const char docente_5[] PROGMEM = "Prof. Paola Guevara";
const char docente_6[] PROGMEM = "Prof. Jesus Tomases";
const char docente_7[] PROGMEM = "Prof. Fredy Charris";
const char docente_8[] PROGMEM = "Prof. Alberto Malagon";
const char docente_9[] PROGMEM = "Prof. Guillermina Garcia";
const char docente_10[] PROGMEM = "Prof. Jose Contreras";
const char docente_11[] PROGMEM = "Prof. Kely Tovar";
const char docente_12[] PROGMEM = "Prof. Alexandra Salazar";
const char docente_13[] PROGMEM = "Prof. ";
const char docente_14[] PROGMEM = "Prof. ";
const char docente_15[] PROGMEM = "Prof. ";
const char docente_16[] PROGMEM = "Prof. ";
const char docente_17[] PROGMEM = "Prof. ";
const char docente_18[] PROGMEM = "Prof. ";
const char docente_19[] PROGMEM = "Prof. ";
const char docente_20[] PROGMEM = "Prof. ";
const char docente_21[] PROGMEM = "Prof. ";
const char docente_22[] PROGMEM = "Prof. ";
const char docente_23[] PROGMEM = "Prof. ";
const char docente_24[] PROGMEM = "Prof. ";
const char docente_25[] PROGMEM = "Prof. ";
const char docente_26[] PROGMEM = "Prof. ";
const char docente_27[] PROGMEM = "Prof. ";
const char docente_28[] PROGMEM = "Prof. ";
const char docente_29[] PROGMEM = "Prof. ";
const char docente_30[] PROGMEM = "Prof. ";
const char* const names[] PROGMEM = {
docente_1, docente_2, docente_3, docente_4, docente_5, docente_6,
docente_7, docente_8, docente_9, docente_10, docente_11, docente_12,
docente_13, docente_14, docente_15, docente_16, docente_17, docente_18,
docente_19, docente_20, docente_21, docente_22, docente_23, docente_24,
docente_25, docente_26, docente_27, docente_28, docente_29, docente_30
#include <Keypad_I2C.h>
#include <Keypad.h> // GDY120705
#include <Wire.h>
#define I2CADDR 0x20
const byte ROWS = 4; //four rows
const byte COLS = 3; //four columns
char hexaKeys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
//byte rowPins[ROWS] = {0, 1, 2, 3}; //PARA KEYPAD 4X3 PLANO P0=F1, P1=F2, P2=F3, P3=F4
//byte colPins[COLS] = {4, 5, 6}; //PARA KEYPAD 4X3 PLANO P4=C1, P5=C2, P6=C3
byte rowPins[ROWS] = {1, 6, 5, 3}; //PARA KEYPAD 4X3 VOLUMETRICO P1=F1, P6=F2, P5=F3, P3=F4
byte colPins[COLS] = {2, 0, 4}; //PARA KEYPAD 4X3 VOLUMETRICO P2=C1, P0=C2, P4=C3
//initialize an instance of class NewKeypad
Keypad_I2C customKeypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS, I2CADDR);
char TECLA; // almacena la tecla presionada
char CLAVE[5]; // almacena en un array 4 digitos ingresados
char CLAVE_MAESTRA[5] = "8888"; // almacena en un array la contraseña maestra
char USUARIO1[5] = "1231"; // JORGE ROYERO
char USUARIO2[5] = "1232"; // JARED
char USUARIO3[5] = "1233"; // SELFY
char USUARIO4[5] = "1234"; // KENDRY
char USUARIO5[5] = "1235"; //
char USUARIO6[5] = "1236"; //
char USUARIO7[5] = "1237"; //
char USUARIO8[5] = "1238"; //
char USUARIO9[5] = "1239"; //
char USUARIO10[5] = "1240"; //
char USUARIO11[5] = "1241"; //
char USUARIO12[5] = "1242";
char USUARIO13[5] = "1243"; //
char USUARIO14[5] = "1244"; //
char USUARIO15[5] = "1245"; //
char USUARIO16[5] = "1246"; //
char USUARIO17[5] = "1247"; //
char USUARIO18[5] = "1248"; //
char USUARIO19[5] = "1249"; //
char USUARIO20[5] = "1250";
char USUARIO21[5] = "1251"; //
char USUARIO22[5] = "1252";
char USUARIO23[5] = "1253"; //
char USUARIO24[5] = "1254"; //
char USUARIO25[5] = "1255"; //
char USUARIO26[5] = "1256"; //
char USUARIO27[5] = "1257"; //
char USUARIO28[5] = "1258"; //
char USUARIO29[5] = "1259"; //
char USUARIO30[5] = "1260";
byte INDICE = 0; // indice del array
Serial.begin(9600); // inicializa comunicacion por monitor serie a 9600 bps
Wire.begin( ); // GDY200622
customKeypad.begin( ); // GDY120705
//lcd.init();
//lcd.backlight();
//lcd.setCursor(0,0);
//lcd.print("Coloque Tarjeta..");
pinMode(buzzer, OUTPUT);
pinMode(ledrojo, OUTPUT);
pinMode(ledverde, OUTPUT);
pinMode(ledazul, OUTPUT);
pinMode(rele, OUTPUT);
digitalWrite (buzzer, LOW);
digitalWrite (ledrojo, LOW);
digitalWrite (ledverde, LOW);
digitalWrite (ledazul, LOW);
digitalWrite (rele, LOW);
SPI.begin(); // inicializa bus SPI
mfrc522.PCD_Init(); // inicializa modulo lector
Serial.println("Listo"); // Muestra texto Listo
Serial.print("Initializing SD card...");
if(!SD.begin(CS_SD)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// Setup for the RTC
if(!rtc.begin()) {
Serial.println("Couldn't find RTC");
while(1);
LeerTeclado();
if ( ! mfrc522.PICC_IsNewCardPresent()) // si no hay una tarjeta presente
return; // retorna al loop esperando por una tarjeta
if ( ! mfrc522.PICC_ReadCardSerial()) // si no puede obtener datos de la tarjeta
return; // retorna al loop esperando por otra tarjeta
Serial.print("UID:"); // muestra texto UID:
for (byte i = 0; i < mfrc522.uid.size; i++) { // bucle recorre de a un byte por vez el UID
if (mfrc522.uid.uidByte[i] < 0x10){ // si el byte leido es menor a 0x10
Serial.print(" 0"); // imprime espacio en blanco y numero cero
else{ // sino
Serial.print(" "); // imprime un espacio en blanco
Serial.print(mfrc522.uid.uidByte[i], HEX); // imprime el byte del UID leido en hexadecimal
LecturaUID[i]=mfrc522.uid.uidByte[i]; // almacena en array el byte del UID leido
Serial.print("\t"); // imprime un espacio de tabulacion
for(int i = 0; i<10; i++){
if(comparaUID(LecturaUID, Usuario[i])){ // llama a funcion comparaUID con Usuario1
char arrayBuf[20]; // crea un búfer
strcpy_P(arrayBuf, pgm_read_word(&(names[i])));
Docente = arrayBuf;
Serial.print("Bienvenido "); // si retorna verdadero muestra texto bienvenida
Serial.println(Docente);
GrabarSdrfid();
delay(30);
else // si retorna falso
Serial.println("No te conozco"); // muestra texto equivalente a acceso denegado
mfrc522.PICC_HaltA(); // detiene comunicacion con tarjeta
} //AQUI FINALIZA EL LOOP
boolean comparaUID(byte lectura[],byte usuario[]) // funcion comparaUID
for (byte i=0; i < mfrc522.uid.size; i++){ // bucle recorre de a un byte por vez el UID
if(lectura[i] != usuario[i]) // si byte de UID leido es distinto a usuario
return(false); // retorna falso
return(true); // si los 4 bytes coinciden retorna verdadero
void GrabarSdrfid(){
digitalWrite(CS_SD,LOW); // Enables SD card chip select pin
myFile=SD.open("DATA.txt", FILE_WRITE);
if (myFile) {
delay(300);
//myFile.print(LecturaUID);
//myFile.print(", ");
DateTime now = rtc.now();
myFile.print(now.year(), DEC);
myFile.print('/');
myFile.print(now.month(), DEC);
myFile.print('/');
myFile.print(now.day(), DEC);
myFile.print(',');
myFile.print(now.hour(), DEC);
myFile.print(':');
myFile.print(now.minute(), DEC);
myFile.print(':');
myFile.print(now.second(), DEC);
myFile.print(',');
myFile.print(Docente); //Nomre del docente
myFile.print(',');
myFile.println("Acceso mediante chip RFID");
Serial.print("Tag UID: ");
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.println(Docente); //Muestra el nombre del docente
Serial.println("sucessfully written on SD card");
delay(300);
myFile.close();
Buzzer();
else {
Serial.println("error opening data.txt");
digitalWrite(CS_SD,HIGH); // Disables SD card chip select pin
void Buzzer(){
digitalWrite(buzzer,HIGH);
digitalWrite (ledverde, HIGH);
delay (100);
digitalWrite(buzzer,LOW);
delay (100);
delay (100);
void BuzzerE(){
digitalWrite (ledrojo, HIGH);
delay (1000);
void LeerTeclado(){
TECLA = customKeypad.getKey(); // obtiene tecla presionada y asigna a variable
if (TECLA) // comprueba que se haya presionado una tecla
CLAVE[INDICE] = TECLA; // almacena en array la tecla presionada
INDICE++; // incrementa indice en uno
Serial.print(TECLA); // envia a monitor serial la tecla presionada
if(INDICE == 4) // si ya se almacenaron los 4 digitos
if(!strcmp(CLAVE, CLAVE_MAESTRA)){ // compara clave ingresada con clave maestra
Serial.println(" Correcta"); // imprime en monitor serial que es correcta la clave
delay (50);
else if(!strcmp(CLAVE, USUARIO1)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[0])));
Docente = arrayBuf;
DateTime fecha = rtc.now(); // funcion que devuelve fecha y horario en formato
//Serial.print("Hola ");
//Serial.println(Docente);
GrabarSdkeypad();//INICIA PROCESO DE ESCRITURA EN LA SD
else if(!strcmp(CLAVE, USUARIO2)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[1])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO3)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[2])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO4)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[3])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO5)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[4])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO6)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[5])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO7)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[6])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO8)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[7])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO9)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[8])));
Docente = arrayBuf;
else if(!strcmp(CLAVE, USUARIO10)){ // compara clave ingresada con clave maestra
strcpy_P(arrayBuf, pgm_read_word(&(names[9])));
Docente = arrayBuf;
else {
Serial.print(fecha.day()); // funcion que obtiene el dia de la fecha completa
Serial.print("/"); // caracter barra como separador
Serial.print(fecha.month()); // funcion que obtiene el mes de la fecha completa
Serial.print(fecha.year()); // funcion que obtiene el año de la fecha completa
Serial.print(" "); // caracter espacio en blanco como separador
Serial.print(fecha.hour()); // funcion que obtiene la hora de la fecha completa
Serial.print(":"); // caracter dos puntos como separador
Serial.print(fecha.minute()); // funcion que obtiene los minutos de la fecha completa
Serial.print(fecha.second()); // funcion que obtiene los segundos de la fecha completa
Serial.println("Contraseña Incorrecta"); // si retorna verdadero muestra texto bienvenida
BuzzerE();
INDICE = 0;
void GrabarSdkeypad(){
if (myFile) {
delay(300);
//myFile.print(CLAVE);
myFile.print('/');
myFile.print('/');
myFile.print(',');
myFile.print(':');
myFile.print(':');
myFile.print(',');
myFile.print(',');
myFile.println("Acceso mediante teclado numerico");
Serial.print("Clave: ");
Serial.print(CLAVE);
Serial.print('/');
Serial.print('/');
Serial.print(':');
Serial.print(':');
delay(300);
myFile.close();
Buzzer();
else {
BuzzerE();
