I get a compiling error, I may have the wrong file. I have an EXPROM in the library.
Used: C:\Users\bandj's\Documents\Arduino\libraries\EXROM
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
I'm new at this. Here is the code.
*** RUN THIS SCRIPT ONLY ONE TIME!!! ***
Author: Michael R. Ross
For more information, see photos and write up at:
Date Created: July 1, 2012
Last Modification: July 4, 2012
Description: This Arduino Script was written to load the initial setup into memory for the
Precision High Speed Photography setup using an Arduino Mega.
This script should only be run one time before loading the main script.
Libraries used:
You will need the EXROM Extention Library for Arduino located at:
http://code.google.com/p/arduino-exrom/downloads/list
You will also need the LCDKeypad Library for the Arduino located at:
http://www.dfrobot.com/image/data/DFR0009/LCDKeypad.zip
The LiquidCrystal Library is also used and is a standard Library with the Arduino software.
// Libraries
#include <LiquidCrystal.h>
#include <LCDKeypad.h>
#include <EXROM.h>
LCDKeypad lcd;
// Set Global Variables
int RunOnce = 0;
// Create arrays to hold Variable Descriptions and Values
char* DescArray[] = {"Flash Delay", "Drop Delay", "Drop Size", "Initial Delay", "Shutter Delay", "MutiFlash", "MultiFlash Delay", "# of Drops", "Valve A Active", "Valve B Active", "Valve C Active", "Vavle D Active", "Valve Delay AB", "Valve Delay BC", "Valve Delay CD","PreFlash Trigger","Sound Threshold","Current Sound","Lightning Threshold","Current Light","IV Start Delay","IV Shutter Speed","IV Interval Secs","IV Intrval MSecs","IV Repetitions"};
float ValueArray[] = {245.0,20.0,85.0,5.0,0.0,1.0,100.0,2.0,1.0,0.0,0.0,0.0,0.0,0.0,0.0,1.0,200.0,0.0,200.0,0.0,0.0,0.0,1.0,0.0,0.0};
char* TypeArray[] = {"Millisecs","Millisecs","Millisecs","Second(s)","Second(s)","Pulses","Millisecs","Drops","0=Off","0=Off","0=Off","0=Off","Millisecs","Millisecs","Millisecs","0=Off","Dn= >Sens","Level","Dn= >Sens","Level","Seconds","Seconds","Seconds","Millisecs","0=Endless"};
float array2[sizeof(ValueArray)];
char* tval;
lcd.begin(16, 2);
lcd.clear();
lcd.print("INITIALIZING ");
lcd.setCursor(0,1);
lcd.print("MEMORY... ");
delay(4000);
if(RunOnce == 0)
lcd.clear();
lcd.print("Saving Values");
lcd.setCursor(0,1);
lcd.print("To Memory...");
delay(4000);
EXROM.write(0, ValueArray, sizeof(ValueArray));
RunOnce = 1;
lcd.clear();
lcd.print("Values Saved!");
delay(4000);
// Read the Paramters from saved memory and update the default
// Array values with those retrieved from memory
EXROM.read(0, array2, sizeof(array2));
if(array2[0] > 0)
for (int i = 0; i < 24; i++)
ValueArray = array2*;*
void UpdateDisplay()
* lcd.clear();*
* lcd.print("Current Values...");*
* delay(1000);*
* for(int k = 0; k < 25; k++)*
* lcd.clear();*
* lcd.print(DescArray[k]);*
* lcd.setCursor(0,1);*
* lcd.print(ValueArray[k]);*
* lcd.setCursor(7,1);*
* lcd.print(TypeArray[k]);*
* delay(1000);*
