wvmarle:
Micros has 1000 for every 1 millis so of course overflows in 1/1000th of the time (just do the maths - 4,294,967,295 ms is about 50 days, 4,294,967,295 us is about 18 mins iirc).
To adjust minutes, adjust your counting every 60,000 milliseconds instead of every 1,000.
Thank you very much sir. But I really don't know how to edit that. Would you be willing to help me with that bit of the code that would do that? Thank you so much. So, do you think that the following would work?
if (millis() - lastTick >= 60000) {
lastTick = millis();
minute++;
Then perhaps, if I am counting in minutes, do I still need the following bit of the code?
// move forward one minute every 60 seconds
if (second >= 60) {
minute++;
second = 0; // reset seconds to zero
Thanks. This is the full code, as it is now:
An open-source binary clock for Arduino.
Based on the code from by Rob Faludi (http://www.faludi.com)
Code under (cc) by Daniel Spillere Andrade, www.danielandrade.net
http://creativecommons.org/license/cc-gpl
int second=0, minute=0, hour=0; //start the time on 00:00:00
int munit,hunit,valm=0,valh=0,ledstats,i;
void setup() { //set outputs and inputs
pinMode(1, OUTPUT);pinMode(2, OUTPUT);pinMode(3, OUTPUT);pinMode(4, OUTPUT);pinMode(5, OUTPUT);
pinMode(6, OUTPUT);pinMode(7, OUTPUT);pinMode(8, OUTPUT);pinMode(9, OUTPUT);pinMode(10, OUTPUT);
pinMode(11, OUTPUT);pinMode(12, OUTPUT);pinMode(13, OUTPUT);
pinMode(0, INPUT);
static unsigned long lastTick = 0; // set up a local variable to hold the last time we moved forward one second
// (static variables are initialized once and keep their values between function calls)
// move forward one second every 1000 milliseconds
if (millis() - lastTick >= 1000) {
second++;
if (second >= 60) {
minute++;
// move forward one hour every 60 minutes
if (minute >=60) {
hour++;
minute = 0; // reset minutes to zero
if (hour >=24) {
hour=0;
munit = minute%10; //sets the variable munit and hunit for the unit digits
hunit = hour%10;
ledstats = digitalRead(0); // read input value, for setting leds off, but keeping count
if (ledstats == LOW) {
for(i=1;i<=13;i++){
digitalWrite(i, LOW);}
//minutes units
if(munit == 1 || munit == 3 || munit == 5 || munit == 7 || munit == 9) { digitalWrite(1, HIGH);} else { digitalWrite(1,LOW);}
if(munit == 2 || munit == 3 || munit == 6 || munit == 7) {digitalWrite(2, HIGH);} else {digitalWrite(2,LOW);}
if(munit == 4 || munit == 5 || munit == 6 || munit == 7) {digitalWrite(3, HIGH);} else {digitalWrite(3,LOW);}
if(munit == 8 || munit == 9) {digitalWrite(4, HIGH);} else {digitalWrite(4,LOW);}
//minutes
if((minute >= 10 && minute < 20) || (minute >= 30 && minute < 40) || (minute >= 50 && minute < 60)) {digitalWrite(5, HIGH);} else {digitalWrite(5,LOW);}
if(minute >= 20 && minute < 40) {digitalWrite(6, HIGH);} else {digitalWrite(6,LOW);}
if(minute >= 40 && minute < 60) {digitalWrite(7, HIGH);} else {digitalWrite(7,LOW);}
//hour units
if(hunit == 1 || hunit == 3 || hunit == 5 || hunit == 7 || hunit == 9) {digitalWrite(8, HIGH);} else {digitalWrite(8,LOW);}
if(hunit == 2 || hunit == 3 || hunit == 6 || hunit == 7) {digitalWrite(9, HIGH);} else {digitalWrite(9,LOW);}
if(hunit == 4 || hunit == 5 || hunit == 6 || hunit == 7) {digitalWrite(10, HIGH);} else {digitalWrite(10,LOW);}
if(hunit == 8 || hunit == 9) {digitalWrite(11, HIGH);} else {digitalWrite(11,LOW);}
//hour
if(hour >= 10 && hour < 20) {digitalWrite(12, HIGH);} else {digitalWrite(12,LOW);}
if(hour >= 20 && hour < 24) {digitalWrite(13, HIGH);} else {digitalWrite(13,LOW);}
valm = analogRead(0); // add one minute when pressed
if(valm<800) {
minute++;
second=0;
delay(250);
valh = analogRead(5); // add one hour when pressed
if(valh<800) {
hour++;
second=0;
delay(250);
