Need help combining two sketches into one
Ok, so heres the deal, i have two working sketches, one for each pin on my Trinket.
the first sketch is meant to control two stands of 5 leds wired into pin 1 (easy right).
it looks like this.........
#ifdef AVR
#include <avr/power.h>
#endif
#define PIN 1
// Parameter 1 = 5
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (AVR_ATtiny85)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
strip.begin();
strip.setBrightness(50);
strip.show(); // Initialize all pixels to 'off'
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(255, 0, 0), 80); // Red
colorWipe(strip.Color(0, 0, 0), 0); // Green
colorWipe(strip.Color(0, 0, 0), 0); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
// Send a theater pixel chase in...
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
The second sketch controls one strip of 5 leds, wired into pin 2 (also easy)
and it looks like this.....
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#ifdef AVR
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN 2
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 5
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 0; // delay for half a second
#endif
pixels.begin(); // This initializes the NeoPixel library.
// For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
for(int i=0;i<NUMPIXELS;i++){
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(0,0,255)); // bright blue color.
pixels.setPixelColor(1, pixels.Color(255,0,0)); // bright red color.
pixels.setPixelColor(2, pixels.Color(0,0,0)); // no color.
pixels.setPixelColor(3, pixels.Color(255,0,0)); // bright red color.
pixels.setPixelColor(4, pixels.Color(0,0,255)); // bright blue color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds).
but when i try to combine them like this.....
#ifdef AVR
#endif
#define PIN 1
// Parameter 1 = 5
#define PIN 2
#define NUMPIXELS 5
#endif
strip.begin();
strip.show();
delay(wait);
I get this error after verifying.......
lawgivermark5:69:1: error: expected unqualified-id before 'for'
lawgivermark5:69:13: error: 'i' does not name a type
lawgivermark5:69:25: error: 'i' does not name a type
exit status 1
Its safe to assume i'm an idiot, for not being able to make work, what seems to be childs play to others.
if anyone could help it would be super appreciated. (just remember, this is all new to me and have no coding background, i'm trying to learn)
Hi, Try this approach:
https://arduinoinfo.mywikis.net/wiki/CombiningArduinoSketches
That for() is outside any function. It was expecting a function to begin there.
Use code tags next time.
thank you both, but i'm still not understanding what i didn't transfer over when combining the two sketches, if there's something important i'm missing, i don't know what it is. this is literally my first time coding. not sure what code tags are either----> () these {} these [] or these
ok i tried to merge them again trying to be very careful with where things go......
#ifdef AVR
#endif
#define PIN 1
// Parameter 1 = 5
#ifdef AVR
#endif
#define PIN 2
#define NUMPIXELS 5
#endif
strip.begin();
#endif
strip.show();
delay(wait);
and now i'm getting this error message.......
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Adafruit Trinket (ATtiny85 @ 8MHz)"
C:\Users\Boba_\Documents\Arduino\sketch_apr06g\sketch_apr06g.ino: In function 'void colorWipe(uint32_t, uint8_t)':
sketch_apr06g:108:1: error: expected '}' at end of input
exit status 1
You've just got your {} in a bit of a mess in colorwipe(). Try using Tools / Auto Format or Ctrl+T in the IDE. That should help you to work out where they should be.
Steve
cool, i think i got it working, no more errors
#ifdef AVR
#endif
#define PIN 1
// Parameter 1 = 5
#ifdef AVR
#endif
#define PIN 2
#define NUMPIXELS 5
#endif
strip.begin();
strip.setBrightness(150);
#endif
for (uint16_t i = 0; i < strip.numPixels(); i++) {
strip.show();
delay(wait);
for (int i = 0; i < NUMPIXELS; i++)
pixels.setPixelColor(i, pixels.Color(0, 0, 255)); // bright blue color.
pixels.setPixelColor(1, pixels.Color(255, 0, 0)); // bright red color.
pixels.setPixelColor(2, pixels.Color(0, 0, 0)); // no color.
pixels.setPixelColor(3, pixels.Color(255, 0, 0)); // bright red color.
pixels.setPixelColor(4, pixels.Color(0, 0, 255)); // bright blue color.
Ok, next time with code tags.
