Need Help! In my project I wanna measure distance of a moving object lets say a train the length <3 m,
I didn't say that
Post #8
Yea I got it, But If u are driving a car the time and velocity of u pulling ur seatbelt isn't gonna be same everytime.
Really?
You need to draw a picture of this. And learn how to spell.
In #16 u said that I am saying "I want the length of a seatbelt at the distance of a moving train" But I definitely didn't said that I only used train as example
I will share a drawing here in evening.(IST)
Look how systems work for measuring length of ropes.
Side note: we expect straight communication here. If your pet project is about measuring seat belts the don’t invent something else. You’ve seen what it does to the thread. Now more time has been spent arguing about your intent than helping you out… lesson for the future…
Measuring the length of seatbelt is just a very small part of my whole project. I can't reveal my whole invention because that could lead to theft of my invention and as you said I'll look upon how measuring of rope works
and you don't have a moral issue asking for guidance, suggestions here and then calling it "YOUR" invention ?
So if you go for something similar, then I want to be part of the inventors when you file for patent.... (patent applications list the inventors who have made significant contributions to the conception of the idea or solution. I think my contribution is very significant).
Can u contact me personally on Discord or instgram?
here is the text for the patent
A cable length measurement system comprising a rotary encoder coupled to a spool of cable, where the encoder tracks the number of spool rotations and calculates the unrolled cable length by correlating the rotations with the spool’s circumference, providing a real-time digital display of the total unrolled length.
or if you don't want to do maths about the changing circumference
A cable length measurement system utilizing a linear displacement sensor that tracks the movement of the cable as it unrolls, where the sensor is mounted along the cable path and continuously measures the distance traveled by the cable, allowing for accurate length measurement even as the spool’s circumference changes due to varying cable thickness or reel diameter.
PS/ I'm joking. have a great 2025. All discussions I'm part of happen here. I'm all for openly sharing.
Oh Thank you very much but still are you open to connect with me personally on Discord or Instagram so that we can coordinate. And I will work upon the info you gave to me
I don't use Discord nor Instagram (nor the other so called social networks)
I only participate here in an "open source" fashion to help, nurture and encourage the next generation of engineers or those with cool projects and as a way to give back now that I'm old and retired.
if you have questions you feel are not covered by your secrecy, I'll be happy to contribute ideas - that can help also someone else.
you'll find many discussion already in the forum about measuring cables. here is one
With that in mind I would consider maybe a YoYo Pot or Draw Wire Sensor. A Google of YoYo Potentiometer or Draw String Potentiometer will get you started. The pot will give you an analog value and in your code you convert the analog in voltage to distance. Less knowing more this is where I would start.
Ron
Hey thanks for your suggestion, I will definitely check that out.
This will never happen. Prove me wrong.
Here you go :), I proved you wrong!
... welcome to ChiPsy101.
One of these:
Okkk, For your information that's not my whole idea, It has many more things than this particular patent :slight_smile:
