I can't seem to get my webclient working even after changing my ipaddress and searching through the web.
My Computer IP address is 172.16.156.53 is there any ip address that i can change to? i tried changing to 172.16.156.39 for the webserver testing and it works fine. Any help will be gladly appreciated. thanks.
Try the below client test code and see if it works.
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
//remove SD card if inserted
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
EthernetClient client;
void setup(){
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.1"); //download text
client.println("Host: web.comporium.net");
client.println("Connection: close"); //close 1.1 persistent connection
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
But i can't seem to get it tested in the serial monitor.
We can't see what you are doing. We can't see what results you got. You need to be way more explicit when reporting results.
Something like:
I copied and pasted the code into the IDE (version x.x.x), and clicked upload. The code successfully compiled, linked, and uploaded.
I then opened the Serial Monitor, and confirmed that the baud rate was set to nnnn.
I saw "xxxxxxxxxxxxxxxxxxx" appear in the output pane, I then .....
