Need Help on Serial Port Behavior
int count=0;
  Serial1.begin(9600);
  Serial3.begin(9600);
  if(Serial.available()>0)
    Serial.print("Number of Bytes:");
    Serial.println(Serial.available());
    while(Serial.available())
      Serial.read();
    Serial1.write("+CMTI: ""SM"",4");
    Serial1.flush();
    count++;
    Serial.print("Count:");
    Serial.println(count);
    delay(100);
  if(Serial3.available()>0)
    while(Serial3.available())
      Serial.write(Serial3.read());
Hi.. Can anyone explain why after running the loop below, there are still some data in the Serial port.
I want loop inside the while loop for once.
      Serial.read();
    Serial1.flush();
Probably there's not still data in the buffer but again. The write on the Serial1 object need some time (more than 10 Milliseconds) and during that time some data may have arrived.
daozui:
I'm not sure what you are trying to achieve but I suspect the problem is that the
empties the serial input buffer long before the full message has time to arrive. The Arduino is very much faster than serial data - even at high baud rates.
Have a look at Serial Input Basics
...R
Thanks.. Putting a delay before goes into the while loop solved the problem.
daozui:
No, it only hides the problem.
You know that the resulting string (+CMTI: SM,4) will not contain any " ?
Whandall:
Nicely put.
...R
Whandall:
You meant no " would be written into the serial1?
  Serial.begin(250000);
  Serial.print(F("Your code produces \""));
  Serial.write("+CMTI: ""SM"",4");
  Serial.print(F("\" but you probably wanted \""));
  Serial.write("+CMTI: \"SM\",4");
  Serial.println(F("\""));
void loop() {}
Your code produces "+CMTI: SM,4" but you probably wanted "+CMTI: "SM",4"
Whandall:
  Serial.print(F("Your code produces ""));
  Serial.print(F("" but you probably wanted ""));
  Serial.write("+CMTI: "SM",4");
  Serial.println(F("""));
void loop() {}
I got what you meant now. I really have trouble on that. Thanks for pointing it out.
Here you can read the details Escape sequences - cppreference.com.
