I found an old code that has the GPS compatible to M6n to M8n GPS the problem is there are changes on the M9n and M10n GPS on the UBX format that prevent this code from working correctly .
#define GPSSERIAL Serial
const unsigned char UBLOX_INIT[] PROGMEM = {
// Disable SBAS
0xB5,0x62,0x06,0x16,0x08,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x25,0x90,
// Disable NMEA
0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x24, // GxGGA off
0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x2B, // GxGLL off
0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x02,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x32, // GxGSA off
0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x03,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x39, // GxGSV off
0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x04,0x00,0x00,0x00,0x00,0x00,0x01,0x04,0x40, // GxRMC off
0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x05,0x00,0x00,0x00,0x00,0x00,0x01,0x05,0x47, // GxVTG off
// Disable UBX
0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0xDC, //NAV-PVT off
0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x12,0xB9, //NAV-POSLLH off
0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0xC0, //NAV-STATUS off
0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x22,0x29, //NAV-VELNED off
// Enable UBX
//0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x07,0x00,0x01,0x00,0x00,0x00,0x00,0x18,0xE1, //NAV-PVT on
//0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x03,0x00,0x01,0x00,0x00,0x00,0x00,0x14,0xC5, //NAV-STATUS on
0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x02,0x00,0x01,0x00,0x00,0x00,0x00,0x13,0xBE, //NAV-POSLLH on
0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x12,0x00,0x01,0x00,0x00,0x00,0x00,0x23,0x2E, //NAV-VELNED on
// Rate
0xB5,0x62,0x06,0x08,0x06,0x00,0x64,0x00,0x01,0x00,0x01,0x00,0x7A,0x12, //(10Hz)
//0xB5,0x62,0x06,0x08,0x06,0x00,0xC8,0x00,0x01,0x00,0x01,0x00,0xDE,0x6A, //(5Hz)
//0xB5,0x62,0x06,0x08,0x06,0x00,0xE8,0x03,0x01,0x00,0x01,0x00,0x01,0x39, //(1Hz)
const unsigned char UBX_HEADER[] = { 0xB5, 0x62 };
const unsigned char NAV_POSLLH_HEADER[] = { 0x01, 0x02 };
const unsigned char NAV_VELNED_HEADER[] = { 0x01, 0x12 };
enum _ubxMsgType {
MT_NONE,
MT_NAV_POSLLH,
MT_NAV_VELNED
struct NAV_POSLLH {
unsigned char cls; // 0x01
unsigned char id; // 0x02
unsigned short len; // 28
unsigned long iTOW; // millisecond time of week
long lon; // longitude
long lat; // latitude
long height; // height above ellipsoid
long hMSL; // height above mean sea level
unsigned long hAcc; // horizontal accuracy
unsigned long vAcc; // vertical accuracy
struct NAV_VELNED {
unsigned char id; // 0x12
unsigned short len; // 36
long velN; // north velocity (cm/s)
long velE; // east velocity (cm/s)
long velD; // down velocity (cm/s)
unsigned long speed; // 3d (cm/s)
unsigned long gSpeed; // ground speed (2d)
long heading; // heading of motion (2d)
unsigned long sAcc; // speed accuracy
unsigned long cAcc; // course/heading accuracy
union UBXMessage {
NAV_POSLLH navPosllh;
NAV_VELNED navVelned;
UBXMessage ubxMessage;
// The last two bytes of the message is a checksum value, used to confirm that the received payload is valid.
// The procedure used to calculate this is given as pseudo-code in the uBlox manual.
void calcChecksum(unsigned char* CK, int msgSize) {
memset(CK, 0, 2);
for (int i = 0; i < msgSize; i++) {
CK[0] += ((unsigned char*)(&ubxMessage))[i];
CK[1] += CK[0];
// Compares the first two bytes of the ubxMessage struct with a specific message header.
// Returns true if the two bytes match.
boolean compareMsgHeader(const unsigned char* msgHeader) {
unsigned char* ptr = (unsigned char*)(&ubxMessage);
return ptr[0] == msgHeader[0] && ptr[1] == msgHeader[1];
// Reads in bytes from the GPS module and checks to see if a valid message has been constructed.
// Returns the type of the message found if successful, or MT_NONE if no message was found.
// After a successful return the contents of the ubxMessage union will be valid, for the
// message type that was found. Note that further calls to this function can invalidate the
// message content, so you must use the obtained values before calling this function again.
int processGPS() {
static int fpos = 0;
static unsigned char checksum[2];
static byte currentMsgType = MT_NONE;
static int payloadSize = sizeof(UBXMessage);
while ( GPSSERIAL.available() ) {
byte c = GPSSERIAL.read();
//Serial.write(c);
if ( fpos < 2 ) {
// For the first two bytes we are simply looking for a match with the UBX header bytes (0xB5,0x62)
if ( c == UBX_HEADER[fpos] )
fpos++;
fpos = 0; // Reset to beginning state.
else {
// If we come here then fpos >= 2, which means we have found a match with the UBX_HEADER
// and we are now reading in the bytes that make up the payload.
// Place the incoming byte into the ubxMessage struct. The position is fpos-2 because
// the struct does not include the initial two-byte header (UBX_HEADER).
if ( (fpos-2) < payloadSize )
((unsigned char*)(&ubxMessage))[fpos-2] = c;
fpos++;
if ( fpos == 4 ) {
// We have just received the second byte of the message type header,
// so now we can check to see what kind of message it is.
if ( compareMsgHeader(NAV_POSLLH_HEADER) ) {
currentMsgType = MT_NAV_POSLLH;
payloadSize = sizeof(NAV_POSLLH);
else if ( compareMsgHeader(NAV_VELNED_HEADER) ) {
currentMsgType = MT_NAV_VELNED;
payloadSize = sizeof(NAV_VELNED);
else {
// unknown message type, bail
fpos = 0;
continue;
if ( fpos == (payloadSize+2) ) {
// All payload bytes have now been received, so we can calculate the
// expected checksum value to compare with the next two incoming bytes.
calcChecksum(checksum, payloadSize);
else if ( fpos == (payloadSize+3) ) {
// First byte after the payload, ie. first byte of the checksum.
// Does it match the first byte of the checksum we calculated?
if ( c != checksum[0] ) {
// Checksum doesn't match, reset to beginning state and try again.
fpos = 0;
else if ( fpos == (payloadSize+4) ) {
// Second byte after the payload, ie. second byte of the checksum.
// Does it match the second byte of the checksum we calculated?
fpos = 0; // We will reset the state regardless of whether the checksum matches.
if ( c == checksum[1] ) {
// Checksum matches, we have a valid message.
return currentMsgType;
else if ( fpos > (payloadSize+4) ) {
// We have now read more bytes than both the expected payload and checksum
// together, so something went wrong. Reset to beginning state and try again.
fpos = 0;
return MT_NONE;
void gps_setup()
GPSSERIAL.begin(9600);
// send configuration data in UBX protocol
for(int i = 0; i < (int)sizeof(UBLOX_INIT); i++) {
GPSSERIAL.write( pgm_read_byte(UBLOX_INIT+i) );
delay(5); // simulating a 38400baud pace (or less), otherwise commands are not accepted by the device.
void gps_loop() {
int msgType = processGPS();
if ( msgType == MT_NAV_POSLLH ) {
/*Serial.print("iTOW:"); Serial.print(posllh.iTOW);
Serial.print(" lat/lon: "); Serial.print(posllh.lat/10000000.0f); Serial.print(","); Serial.print(posllh.lon/10000000.0f);
Serial.print(" height: "); Serial.print(posllh.height/1000.0f);
Serial.print(" hMSL: "); Serial.print(posllh.hMSL/1000.0f);
Serial.print(" hAcc: "); Serial.print(posllh.hAcc/1000.0f);
Serial.print(" vAcc: "); Serial.print(posllh.vAcc/1000.0f);
Serial.println();*/
data.lon = ubxMessage.navPosllh.lon;
data.lat = ubxMessage.navPosllh.lat;
else if ( msgType == MT_NAV_VELNED ) {
data.velN = ubxMessage.navVelned.velN;
data.velE = ubxMessage.navVelned.velE;
