Hey everyone,
First of all, thanks for the help. I am somewhat new at using the Arduino, but have programming background in javascript and visual basic.
I am working on a project for my daughter where I am attempting to animate an alligator head with a servo and sync the movement to audio. I have constructed the head, installed the servo and have it working. I used a pot to test and control the physical head through the arduino and it works great. I also am using a sd shield to store wav files and am using TRMPCM to control the audio.
While I can use the audio volume level to drive the servo position, I really wanted to program the movement myself. I have 4 different short audio clips which I want to be able to select from 4 momentary buttons. I have been successful at initializing the arduino and getting the servo to move using a delay. I have researched and found that delay is probably not what I want to be using to command the servo to move as it appears to stop all other processes and I want to play music during the movements. After looking all around, the only servo examples I have found use either a pot or a digital read to drive position. I want to effectually set the positions manually, but control angle over time.
Any suggestions would be greatly appreciated. I have attached my current code below. I started implementing buttons, but did not finish as I am trying to figure out the servo issue first to see if this is even viable.
Thanks.
#include <SD.h> // need to include the SD library
//#define SD_ChipSelectPin 53 //example uses hardware SS pin 53 on Mega2560
#define SD_ChipSelectPin 10 //using digital pin 4 on arduino nano 328, can use other pins
#include <TMRpcm.h> // also need to include this library...
#include <SPI.h>
#include <Servo.h>
#define BUTTON_PIN 2
#define BUTTON_PIN 3
Servo myservo; // create servo object to control a servo
int pos = 82; // variable to store servo position
int incomingByte; // variable to store byte sent from serial port
TMRpcm tmrpcm; // create an object for use in this sketch
void setup(){
pinMode(BUTTON_PIN, INPUT);
digitalWrite(BUTTON_PIN, HIGH); // connect internal pull-up
tmrpcm.speakerPin = 9; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
myservo.attach(7); // attaches the servo on pin 7 to the servo object
myservo.write(82); // set servo to 40 degrees
delay(4000);
myservo.write(20);
myservo.write(20);
myservo.write(20);
delay(2000);
myservo.write(80);
delay(3000);
myservo.write(20);
myservo.write(20);
delay(100);
myservo.write(82);
if (!SD.begin(SD_ChipSelectPin)) { // see if the card is present and can be initialized:
Serial.println("SD fail");
return; // don't do anything more if not
tmrpcm.play("g_hungry.wav"); //the sound file "music" will play each time the arduino powers up, or is reset
void loop(){
if(Serial.available()){
switch(Serial.read()){ //send the letter p over the serial monitor to start playback
case 'j': myservo.write(20);
tmrpcm.play("g_jaws.wav");
Serial.println("Playing Jaws");
myservo.write(20);
myservo.write(82);
delay(500); break;
case 'b': myservo.write(20);
tmrpcm.play("g_baby.wav");
Serial.println("Playing Baby sounds");
myservo.write(20);
myservo.write(82);
delay(500); break;
default: break;
