Hey i need help converting this code to an IF statement as due to the code it does the opposite than what i want it to do.
what i'm trying to do if there is pressure on an sensor then do nothing else if no pressure on the senor allow the buzzer to go off until pressure if applied
int buzzer = 5; //declares buzzer @pin 5
int FSRanalogpin = A0; //declares the FSR @analogpin A0
int FSRvalue = 0; //saves the analog value as integer
pinMode(FSRanalogpin,INPUT); //sets the FSR as the input
pinMode(buzzer,OUTPUT); //sets the buzzer as the output
FSRvalue = analogRead(FSRanalogpin); //reads the FSR and store it in integer
analogWrite(buzzer,FSRvalue/4); //sets the buzzer duty ratio
no i need help to implement one. with the current code it does if pressure if on the sensor allow buzzer to go off i need it to be the opposite away around .
AWOL:
Can you explain simply what your code does now, and what you want it to do?
the code is above but here it is again
We don't want the code. We want to know what you think the code is actually doing. hint: The code you have written has the buzzer output proportional to the pressure applied. So it does not work in the manner you think it does.
Have you checked the Arduino Reference section on how to write if statement?
right the code works the way it needs to but i need help to change the way it works.
the way i want the code to work to be if the sensor has no pressure the output (buzzer) will continue until the sensor has pressure again which stops the buzzer from working again. so if anyone help rewrite the code to do so it would be a big help.
GypsumFantastic:
OK, let's try a different approach.
Does pressure give you a high FSRvalue, or a low one?
am sorry to say i haven't got a clue what i'm doing am new to all this at the moment the FSRvalue is the sensor and is acting like an on and off switch but with pressure i can link you all to the webpage i went to see if it helps.
You'll probably find that 300 isn't the right value. Move it up and down to set the on/off threshold.
You might find that you need < instead of > in the if command so things might be backwards the way I've written it.
I could have done that. I don't give answers to the basic programming or electronics, because it defeats the learning curve.
