need help with code errors
Cant seem to get this to work any clues??
_10_minute_Blink_with_button_reset:33: error: 'led' was not declared in this scope
digitalWrite(led, HIGH);
C:\Users\Paul\Documents\Arduino\Sketchbook_10_minute_Blink_with_button_reset_10_minute_Blink_with_button_reset.ino: At global scope:
_10_minute_Blink_with_button_reset:46: error: 'switchState' does not name a type
switchState = digitalRead(switchPin);
_10_minute_Blink_with_button_reset:49: error: expected unqualified-id before 'if'
if (switchState != prevSwitchState) {
_10_minute_Blink_with_button_reset:57: error: 'previousTime' does not name a type
previousTime = currentTime;
_10_minute_Blink_with_button_reset:58: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
_10_minute_Blink_with_button_reset.ino (1.62 KB)
The code you posted contains led and LED only in comments. So, it clearly is NOT the code you were compiling.
PaulS:
...although it does fail the compile at the switchState one.
Have a look at the pairing of the { and } braces. The } just above where you try to read the pin into switchState is actually the closing } for loop() so the line in question is not inside loop().
  }  //<<<<<<<<<<<<<<<<<<<<<<<<< this one actually closes loop()
  // read the switch value
Please post the code here rather than attaching it.
Before you do, please read this before posting a programming question and follow the advice given.
