I created this whac-a-mole style game recently, basically copying this tutorial:
The electronics are the same, but I'd like to modify the code. Instead of having a time limit on each hit of the button that gets smaller each hit, I'd like it to have no time limit per hit of button.
Instead, it would have a timer of 60 seconds once the game starts and once the 60 seconds are up, it stops the game and shows your score.
I tried doing this using the millis function, but to no avail. I'm not very familiar with timing things and the millis function. Can someone help me please?
Sorry, I'm pretty new to this forum so don't know how everything works. Here it is:
#include "TM1637.h"
const int CLK = 8; //Set the CLK pin connection to the display
const int DIO = 7; //Set the DIO pin connection to the display
TM1637 tm1637(CLK,DIO); //set up the 4-Digit Display.
int ones = 0;
int tens = 0;
int hundreds = 0;
int thousands = 0;
int gameDelay = 1000; //This is the game speed
int hitButton = 1;
boolean playing = 1; //boolean flag that we'll use to determine where in the scoring cycle we are
int score = 0; //This is the score
void setup(){
//set the button pins
pinMode(2,INPUT_PULLUP);
pinMode(3,INPUT_PULLUP);
pinMode(4,INPUT_PULLUP);
pinMode(5,INPUT_PULLUP);
pinMode(6,INPUT_PULLUP);
pinMode(2,HIGH);
pinMode(3,HIGH);
pinMode(4,HIGH);
pinMode(5,HIGH);
pinMode(6,HIGH);
//set the led pins
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
tm1637.init();
tm1637.set(BRIGHTEST);//BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
void loop(){
while(keyPress()==0){
//Serial.println("wait for input");
} //Wait for a key press to start the game
gameDelay = 1000;
playing = 1; //Reset the flag from last game
gameRunning(); //Start the Game
//This function will flash all buttons and wait for a button press to start the game.
//Speed will be set depending on which button is pressed
boolean keyPress(){
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, HIGH);
digitalWrite(12, HIGH);
digitalWrite(13, HIGH);
delay(50);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(12, LOW);
digitalWrite(13, LOW);
delay(50);
boolean pressed = 0;
if(digitalRead(2)==LOW || digitalRead(3)==LOW || digitalRead(4)==LOW || digitalRead(5)==LOW || digitalRead(6)==LOW){
pressed = 1;
return pressed;
void gameRunning(){
score = 0;
int newLED; //This is the the LED that we're goign to light next
randomSeed(analogRead(A0)); //Random Seed
while(playing == 1){
playing=0;
byte randomLed = random(9,14); // pick a random LED
while(newLED == randomLed){ //make sure it's not the same as the last one
newLED = randomLed;
//Serial.println(newLED); //Serial debug stuff
int newButton = getButton(newLED); //The getButton function returns the button number corresponding to the LED that's on.
digitalWrite(newLED, HIGH); //Light up the random LED.
for(int t=0; t<gameDelay; t++){ //Game cycles delay
hitButton = digitalRead(newButton); //Grab the button status
if(hitButton==0){
playing=1;
} //if button was pressed
delay(1);
digitalWrite(newLED, LOW); //turn off the LED
score=score+1; //increase the score
gameDelay=(gameDelay-15); //Speed up the game after every button press
ones = score%10;
tens = (score/10)%10;
hundreds = (score/100)%10;
thousands = (score/1000)%10;
tm1637.display(3,ones);
tm1637.display(2,tens);
tm1637.display(1,hundreds);
tm1637.display(0,thousands);
//This functio returns the corresponding button pin for a given LED pin.
int getButton(int newLED){
int Button;
switch (newLED) {
case 9:
Button = 2;
case 10:
Button = 3;
case 11:
Button = 4;
case 12:
Button = 5;
case 13:
Button = 6;
return Button;
As the title suggests, it should be read before posting a programming question. Please read it now. Pay particular attention to Item #6 which explains how to properly post your code with Code Tags.
int Button;
switch (newLED) {
case 9:
Button = 2;
case 10:
Button = 3;
case 11:
Button = 4;
case 12:
Button = 5;
case 13:
Button = 6;
return Button;
//This function returns the corresponding button pin for a given LED pin.
return newLED - 7;
