Need help with code, using rosserial in motor control
Actually I am using this code from this tutorial which uses ROS Click here
DETAILS:
ROS (JETSON NANO)
ARDUINO MEGA 11TH PIN CONNECTED TO S1 OF SABERTOOTH 2 X 32 MOTOR DRIVER, ORAGNE ENCODER1 CONNECTED TO 2,3 , ORANGE ENCODER 2 CONNECTED TO 18,19, WORKS FINE, But MY MOTOR IS NOT RUNNING WHILE I USE
ROSCORE
rosrun rosserial_arduino serial_node.py _port:=/dev/ttyUSB0 _baud:=115200
rosrun rqt_robot_steering rqt_robot_steering
and for using my controller , i have edited the arduino code like this,
#include <ros.h>
#include <std_msgs/Int16.h>
#include <geometry_msgs/Twist.h>
#include <SoftwareSerial.h>
#include <SabertoothSimplified.h>
#include <Sabertooth.h>
SoftwareSerial SWSerial(NOT_A_PIN, 11); // RX on no pin (unused), TX on pin 11 (to S1).
Sabertooth ST(128, SWSerial); // Address 128, and use SWSerial as the serial port.
// Handles startup and shutdown of ROS
ros::NodeHandle nh;
////////////////// Tick Data Publishing Variables and Constants ///////////////
int encoderPin1 = 2;
int encoderPin2 = 3;
int encoderPin3 = 18;
int encoderPin4 = 19;
// True = Forward; False = Reverse
boolean Direction_left = true;
boolean Direction_right = true;
// Minumum and maximum values for 16-bit integers
// Range of 65,535
const int encoder_minimum = -32768;
const int encoder_maximum = 32767;
volatile int lastEncoded = 0;
//volatile long encoderValue = 0;
volatile int lastEncoded1 = 0;
long lastencoderValue = 0;
long lastencoderValue1 = 0;
std_msgs::Int16 encoderValue;
ros::Publisher rightPub("right_ticks", &encoderValue);
std_msgs::Int16 encoderValue1;
ros::Publisher leftPub("left_ticks", &encoderValue1);
// Time interval for measurements in milliseconds
const int interval = 30;
long previousMillis = 0;
long currentMillis = 0;
////////////////// Motor Controller Variables and Constants ///////////////////
// Motor A connections
const int enA = 9;
const int in1 = 5;
const int in2 = 6;
// Motor B connections
const int enB = 10;
const int in3 = 7;
const int in4 = 8;
// How much the PWM value can change each cycle
const int PWM_INCREMENT = 1;
// Number of ticks per wheel revolution. We won't use this in this code.
const int TICKS_PER_REVOLUTION = 610;
// Wheel radius in meters
const double WHEEL_RADIUS = 0.127;
// Distance from center of the left tire to the center of the right tire in m
const double WHEEL_BASE = 0.715;
// Number of ticks a wheel makes moving a linear distance of 1 meter
// This value was measured manually.
const double TICKS_PER_METER = 762; // Originally 2880
// Proportional constant, which was measured by measuring the
// PWM-Linear Velocity relationship for the robot.
const int K_P = 278;
// Y-intercept for the PWM-Linear Velocity relationship for the robot
const int b = 52;
// Correction multiplier for drift. Chosen through experimentation.
const int DRIFT_MULTIPLIER = 120;
// Turning PWM output (0 = min, 255 = max for PWM values)
const int PWM_TURN = 80;
// Set maximum and minimum limits for the PWM values
const int PWM_MIN = 80; // about 0.1 m/s
const int PWM_MAX = 100; // about 0.172 m/s
// Set linear velocity and PWM variable values for each wheel
double velLeftWheel = 0;
double velRightWheel = 0;
double pwmLeftReq = 0;
double pwmRightReq = 0;
// Record the time that the last velocity command was received
double lastCmdVelReceived = 0;
void updateEncoder() {
  int MSB = digitalRead(encoderPin1); //MSB = most significant bit
  int LSB = digitalRead(encoderPin2); //LSB = least significant bit
  int encoded = (MSB << 1) | LSB; //converting the 2 pin value to single number
  int sum  = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
  if (sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue.data ++;
  if (sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue.data --;
  lastEncoded = encoded; //store this value for next time
void updateEncoder1() {
  int MSB = digitalRead(encoderPin3); //MSB = most significant bit
  int LSB = digitalRead(encoderPin4); //LSB = least significant bit
  int encoded1 = (MSB << 1) | LSB; //converting the 2 pin value to single number
  int sum1  = (lastEncoded1 << 2) | encoded1; //adding it to the previous encoded value
  if (sum1 == 0b1101 || sum1 == 0b0100 || sum1 == 0b0010 || sum1 == 0b1011) encoderValue1.data ++;
  if (sum1 == 0b1110 || sum1 == 0b0111 || sum1 == 0b0001 || sum1 == 0b1000) encoderValue1.data --;
  lastEncoded1 = encoded1; //store this value for next time
/////////////////////// Motor Controller Functions ////////////////////////////
// Calculate the left wheel linear velocity in m/s every time a
// tick count message is rpublished on the /left_ticks topic.
void calc_vel_left_wheel() {
  // Previous timestamp
  static double prevTime = 0;
  // Variable gets created and initialized the first time a function is called.
  static int prevLeftCount = 0;
  // Manage rollover and rollunder when we get outside the 16-bit integer range
  int numOfTicks = (65535 + encoderValue1.data - prevLeftCount) % 65535;
  // If we have had a big jump, it means the tick count has rolled over.
  if (numOfTicks > 10000) {
    numOfTicks = 0 - (65535 - numOfTicks);
  // Calculate wheel velocity in meters per second
  velLeftWheel = numOfTicks / TICKS_PER_METER / ((millis() / 1000) - prevTime);
  // Keep track of the previous tick count
  prevLeftCount = encoderValue1.data;
  // Update the timestamp
  prevTime = (millis() / 1000);
// Calculate the right wheel linear velocity in m/s every time a
// tick count message is published on the /right_ticks topic.
void calc_vel_right_wheel() {
  static int prevRightCount = 0;
  int numOfTicks = (65535 + encoderValue.data - prevRightCount) % 65535;
  velRightWheel = numOfTicks / TICKS_PER_METER / ((millis() / 1000) - prevTime);
  prevRightCount = encoderValue.data;
// Take the velocity command as input and calculate the PWM values.
void calc_pwm_values(const geometry_msgs::Twist& cmdVel) {
  // Record timestamp of last velocity command received
  lastCmdVelReceived = (millis() / 1000);
  // Calculate the PWM value given the desired velocity
  pwmLeftReq = K_P * cmdVel.linear.x + b;
  pwmRightReq = K_P * cmdVel.linear.x + b;
  // Check if we need to turn
  if (cmdVel.angular.z != 0.0) {
    // Turn left
    if (cmdVel.angular.z > 0.0) {
      pwmLeftReq = -PWM_TURN;
      pwmRightReq = PWM_TURN;
    // Turn right
    else {
      pwmLeftReq = PWM_TURN;
      pwmRightReq = -PWM_TURN;
  // Go straight
  else {
    // Remove any differences in wheel velocities
    // to make sure the robot goes straight
    static double prevDiff = 0;
    static double prevPrevDiff = 0;
    double currDifference = velLeftWheel - velRightWheel;
    double avgDifference = (prevDiff + prevPrevDiff + currDifference) / 3;
    prevPrevDiff = prevDiff;
    prevDiff = currDifference;
    // Correct PWM values of both wheels to make the vehicle go straight
    pwmLeftReq -= (int)(avgDifference * DRIFT_MULTIPLIER);
    pwmRightReq += (int)(avgDifference * DRIFT_MULTIPLIER);
  // Handle low PWM values
  if (abs(pwmLeftReq) < PWM_MIN) {
    pwmLeftReq = 0;
  if (abs(pwmRightReq) < PWM_MIN) {
    pwmRightReq = 0;
void set_pwm_values() {
  // These variables will hold our desired PWM values
  static int pwmLeftOut = 0;
  static int pwmRightOut = 0;
  // If the required PWM is of opposite sign as the output PWM, we want to
  // stop the car before switching direction
  static bool stopped = false;
  if ((pwmLeftReq * velLeftWheel < 0 && pwmLeftOut != 0) ||
      (pwmRightReq * velRightWheel < 0 && pwmRightOut != 0)) {
    pwmLeftReq = 0;
    pwmRightReq = 0;
  // Increase the required PWM if the robot is not moving
  if (pwmLeftReq != 0 && velLeftWheel == 0) {
    pwmLeftReq *= 50;
  if (pwmRightReq != 0 && velRightWheel == 0) {
    pwmRightReq *= 50;
  // Calculate the output PWM value by making slow changes to the current value
  if (abs(pwmLeftReq) > pwmLeftOut) {
    pwmLeftOut += PWM_INCREMENT;
  else if (abs(pwmLeftReq) < pwmLeftOut) {
    pwmLeftOut -= PWM_INCREMENT;
  else {}
  if (abs(pwmRightReq) > pwmRightOut) {
    pwmRightOut += PWM_INCREMENT;
  else if (abs(pwmRightReq) < pwmRightOut) {
    pwmRightOut -= PWM_INCREMENT;
  else {}
  // Conditional operator to limit PWM output at the maximum
  pwmLeftOut = (pwmLeftOut > PWM_MAX) ? PWM_MAX : pwmLeftOut;
  pwmRightOut = (pwmRightOut > PWM_MAX) ? PWM_MAX : pwmRightOut;
  // PWM output cannot be less than 0
  pwmLeftOut = (pwmLeftOut < 0) ? 0 : pwmLeftOut;
  pwmRightOut = (pwmRightOut < 0) ? 0 : pwmRightOut;
  /* Set the PWM value on the pins
  analogWrite(enA, pwmLeftOut);
  analogWrite(enB, pwmRightOut);*/
  // Set the direction of the motors
  if (pwmLeftReq > 0) { // Left wheel forward
    ST.motor(1, pwmLeftOut);//left_motor_forward
  else if (pwmLeftReq < 0) { // Left wheel reverse
    ST.motor(1, -pwmLeftOut);//left_motor_forward
  else if (pwmLeftReq == 0 && pwmLeftOut == 0 ) { // Left wheel stop
    ST.motor(1, 0);
  else { // Left wheel stop
    ST.motor(1, 0);
  if (pwmRightReq > 0) { // Right wheel forward
    ST.motor(2, -pwmRightOut);//right_motor_forward
  else if (pwmRightReq < 0) { // Right wheel reverse
    ST.motor(2, pwmRightOut);//right_motor_reverse
  else if (pwmRightReq == 0 && pwmRightOut == 0) { // Right wheel stop
    ST.motor(2, 0);
  else { // Right wheel stop
    ST.motor(2, 0);
// Set up ROS subscriber to the velocity command
ros::Subscriber<geometry_msgs::Twist> subCmdVel("cmd_vel", &calc_pwm_values );
  // Set pin states of the encoder
  pinMode(encoderPin1, INPUT);
  pinMode(encoderPin2, INPUT);
  pinMode(encoderPin3, INPUT);
  pinMode(encoderPin4, INPUT);
  digitalWrite(encoderPin1, HIGH); //turn pullup resistor on
  digitalWrite(encoderPin2, HIGH); //turn pullup resistor on
  digitalWrite(encoderPin3, HIGH); //turn pullup resistor on
  digitalWrite(encoderPin4, HIGH); //turn pullup resistor on
  //call updateEncoder() when any high/low changed seen
  //on interrupt 0 (pin 2), or interrupt 1 (pin 3)
  attachInterrupt(digitalPinToInterrupt(encoderPin1), updateEncoder, CHANGE); //attachInterrupt(digitalPinToInterrupt(pin), ISR, mode)
  attachInterrupt(digitalPinToInterrupt(encoderPin2), updateEncoder, CHANGE);
  attachInterrupt(digitalPinToInterrupt(encoderPin3), updateEncoder1, CHANGE); //attachInterrupt(digitalPinToInterrupt(pin), ISR, mode)
  attachInterrupt(digitalPinToInterrupt(encoderPin4), updateEncoder1, CHANGE);
  // Turn off motors - Initial state
  digitalWrite(in1, LOW);
  digitalWrite(in2, LOW);
  digitalWrite(in3, LOW);
  digitalWrite(in4, LOW);
  // Set the motor speed
  analogWrite(enA, 0);
  analogWrite(enB, 0);
  // ROS Setup
  nh.getHardware()->setBaud(115200);
  nh.initNode();
  nh.advertise(rightPub);
  nh.advertise(leftPub);
  nh.subscribe(subCmdVel);
  nh.spinOnce();
  // Record the time
  currentMillis = millis();
  // If the time interval has passed, publish the number of ticks,
  // and calculate the velocities.
  if (currentMillis - previousMillis > interval) {
    // Publish tick counts to topics
    rightPub.publish(&encoderValue);
    leftPub.publish(&encoderValue1);
    // Calculate the velocity of the right and left wheels
    calc_vel_right_wheel();
    calc_vel_left_wheel();
    //set_pwm_values();
  // Stop the car if there are no cmd_vel messages
  if ((millis() / 1000) - lastCmdVelReceived > 1) {
    pwmLeftReq = 0;
    pwmRightReq = 0;
  set_pwm_values();
TOPICS LIKE TICKS, CMD_VEL EVERYTHING IS PUBLISHED, BUT MY MOTORS CONTROLLED USING SABERTOOTH 2 X32 MOTOR DRIVER IS NOT RUNNING
why not work with simpler code to just get a motor to work
i don't see where the motor enA or enB pins are set to anything other than zero.
why are these commented out?
tried with this code, and the motor works fine, its just this particular code, i am not able to make it run, i am using sabertooth motor driver, so can't go ahead with this piece of code, as sabertooth motor driver itself a computer, they communicate using serial communication, the working code i will post below
#include <math.h>
SoftwareSerial portROS(0, 1);
const long CONTROL_TIMEOUT = 1000; //ms to wait  before killing motors
void cmdVelCallback(const geometry_msgs::Twist&);
//ros::NodeHandle nh;
//volatile long encoderValue1 = 0;
int lastMSB = 0;
int lastLSB = 0;
int lastMSB1 = 0;
int lastLSB1 = 0;
// 100ms interval for measurements
const int interval = 100;
ros::NodeHandle handle;
ros::Subscriber<geometry_msgs::Twist> subscriber("cmd_vel", &cmdVelCallback);
geometry_msgs::Twist msg;
ros::Publisher chatter_pub("cmd_vel", &msg);
unsigned long lastData = 0;
int cnt = 0;
void cmdVelCallback(const geometry_msgs::Twist &twist)//motor control serial
  if (cnt % 2 == 0)
    digitalWrite(2, HIGH);
    digitalWrite(2, LOW);
  cnt = cnt + 1;
  // this function is called as soon as there is any cmd_vel command in the ros network
  lastData = millis();
  // this variable is given forth/back velocity in range of [-0.5 +0.5]
  const float linear = twist.linear.x;
  // this variable is given left/right velocity in range of [-1 +1]
  const float spin = twist.angular.z;
  // give movement to forth/back direction
  front(int(66 * linear));
  // if given command is right means spin is negative
  if (spin < 0)
    turn1(int(100 * spin));
  else if (spin > 0)
  setupfn();
  //delay(1000);
  handle.spinOnce();
  //nh.spinOnce();
  if (millis() - lastData >= CONTROL_TIMEOUT)// for motors
    msg.linear.x = 0;
    msg.angular.z = 0;
    chatter_pub.publish(&msg);
  if (currentMillis - previousMillis > interval) {//for encoders
void setupfn()
  SWSerial.begin(9600);
  ST.autobaud();
  portROS.begin(57600);
  //Serial.begin(9600);
  handle.initNode();
  handle.subscribe(subscriber);
  handle.advertise(chatter_pub);
  handle.advertise(rightPub);
  handle.advertise(leftPub);
int front(int propel) {
  ST.motor(1, -propel);
  ST.motor(2, propel);
int turn1(signed int rueck) {
  ST.motor(1, -rueck);
  ST.motor(2, -rueck);
void standgas() {
  ST.motor(1, 0);
  ST.motor(2, 0);
