I am trying to debounce switches in an existing sketch that I am wanting to use. Have tried a few methods of debouncing that I found on various places on the net but can't get it integrated in what I already have and as a newbie I am at a loss. The relevant parts of the sketch are:
// For pushButtons:
int pushButton = 0;
if (digitalRead(22)) {
if (pushButton !=22) {
pushButton=22;
Serial.println("Input 1");
AtemSwitcher.changePreviewInput(1);
} else if (pushButton==22) {
pushButton = 0;
if (digitalRead(23)) {
if (pushButton !=23) {
pushButton=23;
Serial.println("Select 2");
AtemSwitcher.changePreviewInput(2);
} else if (pushButton==23) {
pushButton = 0;
I have shown only two of the fifteen switches. I get debounce errors both at the make and the break. Any and all help is appreciated.
kaaskop:
Here is some code you can use for any number of mechanical buttons and switches:
#define INPUTMODE INPUT_PULLUP // INPUT or INPUT_PULLUP
#define BOUNCETIME 5 // bouncing time in milliseconds
byte buttonPins[]={2, 3, 4, 5, 6};// pin numbers of all buttons
#define NUMBUTTONS sizeof(buttonPins) // number of buttons (automatically calculated)
byte buttonState[NUMBUTTONS]; // array holds the actual HIGH/LOW states
byte buttonChange[NUMBUTTONS]; // array holds the state changes when button is pressed or released
enum{UNCHANGED,BUTTONUP,BUTTONDOWN};
void input(){
// read the input state and state changes of all buttons
static unsigned long lastButtonTime; // time stamp for remembering the time when the button states were last read
memset(buttonChange,0,sizeof(buttonChange)); // reset all old state changes
if (millis()-lastButtonTime<BOUNCETIME) return; // within bounce time: leave the function
lastButtonTime=millis(); // remember the current time
for (int i=0;i<NUMBUTTONS;i++)
byte curState=digitalRead(buttonPins[i]); // current button state
if (INPUTMODE==INPUT_PULLUP) curState=!curState; // logic is inverted with INPUT_PULLUP
if (curState!=buttonState[i]) // state change detected
if (curState==HIGH) buttonChange[i]=BUTTONDOWN;
else buttonChange[i]=BUTTONUP;
buttonState[i]=curState; // save the current button state
void output(){
// send a message to Serial if a button state (pressed/released) has changed
// button pressed: Send button pin number with minus sign
// button released: Send button pin number
byte action;
switch (buttonChange[i])
case BUTTONUP: Serial.println(buttonPins[i]);break;
case BUTTONDOWN: Serial.println(-buttonPins[i]);break;
Serial.begin(9600); // initialize Serial at 9600 baud
// then initialize all buttons
for (int i=0;i<NUMBUTTONS;i++) pinMode(buttonPins[i],INPUTMODE);
input();
// processing(); // if you need any processing, write a function for it!
output();
I'm always using the IPO programming model for arduino sketches in the loop:
input
processing
output
In the code define INPUTMODE accordingly to the usage of pull-resistors in your circuit:
when using no pull-resistors or external pull-up resistors ==> INPUT_PULLUP
when using external pull-down resistors ==> INPUT
In the demo sketch, input is taken from the buttons, not any processing is done, and the output is a short message on Serial when a button was pressed or released.
