hi! i got an "DHT22" on pcb. like this: DHT22 on PCB
I get it to work and show temp and humid, but the temp atleast is wrong with a couple of degrees :S can someone help with that?
DHT22 sensors are pretty unprecise. So if you want to keep the DHT22 sensor you could write a correction-table as an array.
This correction-array will need RAM. So it is important to know what exact type of microcontroller you are using.
If you want a more precise temperature and precise humdity use a SHT-sensor instead of the DHT22.
If you want more precision use a SHT40
https://www.ebay.de/itm/156039869674
very good temperature precision of 0,1 °C can be achieved with a TMP117
https://www.digikey.de/de/products/detail/adafruit-industries-llc/4821/13571586
0.5°C degree precision can be achieved with DS18B20 sensors.
best regards Stefan
Too high, too low, high and low?
Using a DHT and a true thermometer, record these temperatures after 10 minutes
The error percent at each measurement is: ((measured - true) / true) * 100.
If the error percent is the same at each temperature, use that value for every DHT reading.
If the error percent graph at each "true" temperature is not flat, draw a "best fit" line, then use the point-slope equation of that line (y = mx + b) on every DHT reading.
