need help with programming
i have a micro sd card module in which i have saved two audio named 0001.wav and 0002.wav. a ultrasonic detects a object in range and blinks the leds. the code for detection and blinking led works fine but when i added the code for audio, it does not work. please help me out with it.
        [ #include <SD.h> // need to include the SD library
#define SD_ChipSelectPin 4
#include <TMRpcm.h> // also need to include this library...
#include <SPI.h>
TMRpcm tmrpcm; // create an object for use in this sketc
int step = 0;
int led1 = 7;
int led2 = 8;
int led3 = 2;
const int echoPin1 = 6;
const int trigPin1 = 5;
long duration1;
int distance1;
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
tmrpcm.speakerPin = 9;
myservo1.attach(3);
static unsigned lastMilli = 0;
static unsigned lastLED = 2;
static const byte LEDs[] = { led1, led2, led3 };
digitalWrite(trigPin1, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin1, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration1 = pulseIn(echoPin1, HIGH);
// Calculating the distance
distance1=(duration1/2)/29.1;
// Prints the distance on the Serial Monitor
Serial.print("Distance1: ");
Serial.println(distance1);
delay(100);
switch(step) {
case 0: do_step_0(); break;
case 1: do_step_1(); break;
case 2: do_step_2(); break;
case 3: do_step_3(); break;
case 4: do_step_4(); break;
void do_step_0() {
if ((distance1>7) && (distance1<=20))
step = 1;
myservo1.write(0);
void do_step_1() {
myservo1.write(150);
step = 2;
void do_step_2() {
tmrpcm.play("0001.wav");
digitalWrite(led1,HIGH);
digitalWrite(led1,LOW);
step = 3;
else {
step = 0;
void do_step_3() {
tmrpcm.play("0002.wav");
digitalWrite(led2,HIGH);
digitalWrite(led2,LOW);
step = 4;
else {
step = 0;
void do_step_4() {
digitalWrite(led3,HIGH);
digitalWrite(led3,LOW);
step = 2;
else {
step = 0;
Why did you start a new thread on this subject? You made a mistake and posted this in the code of your other thread, where it couldn't be seen, instead of in the body of the reply, so no one knew you were having problems:-
but the problem is that the audio does not play, only the leds blink.
All that you had to do was edit and correct your last reply in the original thread, not start another thread with the same title which once again doesn't mention what the actual problem is.
"need help with programming" is a very poor choice for a thread title.
Cross-posting is not allowed on these forums.
