My code:
#include <Joystick.h>
// Create the Joystick
Joystick_ Joystick;
// Constant that maps the phyical pin to the joystick button.
const int pin1 = 8;
const int pin0 = 3;
// Initialize Button Pins
pinMode(pin1, INPUT_PULLUP);
pinMode(pin0, INPUT_PULLUP);
// Initialize Joystick Library
Joystick.begin();
// Last state of the button
// Read pin values
if (1==digitalRead(pin1)){
Joystick.setButton(0,1); Joystick.setButton(1,0); Joystick.setButton(2,0);}
else {
if(1==digitalRead(pin0)){
Joystick.setButton(0,0); Joystick.setButton(1,1); Joystick.setButton(2,0);}
else{
Joystick.setButton(0,0); Joystick.setButton(1,0); Joystick.setButton(2,1);}
delay(50);
The foundation comes from the simple example from the website of the joystick library. I tried to modify it for a 3way switch.
In theory, there should be a different output for each case, when pin0 is connected, when pin1 is connected and when nothing is connected. At the moment it works for pin1 and when nothing is connected, but not for pin0. I know that the problem lies somewhere here:
else {
else{
because if I swap pin1 and pin0 in this part of the code it works for the latter but not for pin1.
Thanks for your help in advance.
