I am attempting to automate lifting a painting 52" wide x 33.5" tall that is hinged at the top. I am open to suggestions as to the best way to accomplish this task. I saw a YouTube video on stepper motors controlled be Arduino and here I am.
I am trying to have an Arduino Uno control a Nema 17 stepper motor using a micro switch to home the motor and a remote control (NEC) to move the motor 90 degrees from home with CH+ and back to home with CH-
I know nothing about programming. I pieced together the code listed below and cannot find information to help troubleshoot. I would greatly appreciate help fixing the current code or an entirely different code if needed.
The code uploads without error. The motor will home and "Stepper is homing" will print on the serial monitor and then nothing else will happen.
Connections are as follows:
Nema 17 black and green wires to "A" and red and blue to "B" on EasyDr1ver HW-135.
Both EasyDr1ver grounds to Uno. EasyDr1ver power to 5v on Uno. EasyDr1ver Step to
digital pin 2, Dir to digital pin 3.
Micro switch C to ground and NO to Uno digital pin 9.
IR receiver VCC to Uno 5v, ground to ground and IN to Uno digital pin 4.
#include"IRremote.h"
#include "AccelStepper.h"
// Library created by Mike McCauley at AccelStepper: AccelStepper library for Arduino
// AccelStepper Setup
AccelStepper stepperX(1, 2, 3); // 1 = Easy Driver interface
// NANO Pin 2 connected to STEP pin of Easy Driver
// NANO Pin 3 connected to DIR pin of Easy Driver
// Define the Pins used
#define home_switch 9 // Pin 9 connected to Home Switch (MicroSwitch)
// Stepper Travel Variables
long Travelx; // Used to store the X value entered in the Serial Monitor
int move_finished=1; // Used to check if move is completed
long initial_homing=-1; // Used to Home Stepper at startup
int receiver = 4; //Signal Pin of IR receiver to Arduino Digital Pin 4
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
Serial.begin(9600); // Start the Serial monitor with speed of 9600 Bauds
pinMode(home_switch, INPUT_PULLUP);
delay(5); // Wait for EasyDriver wake up
// Set Max Speed and Acceleration of each Steppers at startup for homing
stepperX.setMaxSpeed(100.0); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperX.setAcceleration(100.0); // Set Acceleration of Stepper
// Start Homing procedure of Stepper Motor at startup
Serial.print("Stepper is Homing . . . . . . . . . . . ");
while (digitalRead(home_switch)); { // Make the Stepper move CCW until the switch is activated
stepperX.moveTo(initial_homing); // Set the position to move to
initial_homing--; // Decrease by 1 for next move if needed
stepperX.run(); // Start moving the stepper
delay(5);
stepperX.setCurrentPosition(0); // Set the current position as zero for now
initial_homing=1;
while (!digitalRead(home_switch)); { // Make the Stepper move CW until the switch is deactivated
stepperX.run();
initial_homing++;
delay(5);
irrecv.enableIRIn(); // Start the receiver
void loop(){
if (irrecv.decode(&results)); //IR signal received?
switch(results.value)
case 0xEE886D7F: //CH+ Pressed
stepperX.setSpeed(1000); //Set stepper speed
stepperX.moveTo(1480);
stepperX.run();
delay(2000);
case 0xE318261B: //CH- Pressed
stepperX.moveTo(-1480);
stepperX.run();
delay(2000);
irrecv.resume();// Receive next value
