That works too with a long press at any time
oops. @UKHeliBob yes you are right the original code does the same.
So it was a "peace of cake" for chatGPT to leave the code as it is.
In the meantime I compiled the code in the arduino IDE version1.8.19
it spits out this error
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola.cpp:41:21: error: void value not ignored as it ought to be
never encountered such an error before.
Seems to be in the library. So what is wrong here?
the function with the error
bool MD_Parola::begin(uint8_t numZones)
bool b = _D.begin(); // method return status
// Check boundaries for the number of zones
if (numZones == 0) numZones = 1;
#if STATIC_ZONES
if (numZones > MAX_ZONES) numZones = MAX_ZONES; // static zones
#endif
_numZones = numZones;
#if !STATIC_ZONES
// Create the zone objects array for dynamic zones
_Z = new MD_PZone[_numZones];
b = b && (_Z != nullptr);
#endif
if (b)
for (uint8_t i = 0; (i < _numZones) && b; i++)
b = b && _Z[i].begin(&_D);
if (b)
// for one zone automatically make it all modules, user will override if not intended
if (_numZones == 1)
setZone(0, 0, _numModules - 1);
// set the default intensity for the whole display without knowing zone boundaries
_D.control(0, _numModules - 1, MD_MAX72XX::INTENSITY, DEFAULT_INTENSITY);
// initialize zone-independent options
setSpeedInOut(10, 10);
setPause(10 * getSpeed());
setCharSpacing(1);
setScrollSpacing(0);
setTextAlignment(PA_LEFT);
setTextEffect(PA_PRINT, PA_NO_EFFECT);
setInvert(false);
return(b);
The complete cpp-file
MD_Parola - Library for modular scrolling text and Effects
See header file for comments
Copyright (C) 2013 Marco Colli. All rights reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <MD_Parola.h>
#include <MD_Parola_lib.h>
//#include <MD_MAX72xx.h>
* \file
* \brief Implements core MD_Parola class methods
MD_Parola::~MD_Parola(void)
#if !STATIC_ZONES
// release the dynamically allocated zone array
delete[] _Z;
#endif
#if STATIC_ZONES
#endif
#if !STATIC_ZONES
#endif
if (b)
if (b)
if (_numZones == 1)
setCharSpacing(1);
setInvert(false);
return(b);
bool MD_Parola::setZone(uint8_t z, uint8_t moduleStart, uint8_t moduleEnd)
if ((moduleStart <= moduleEnd) && (moduleEnd < _numModules) && (z < _numZones))
_Z[z].setZone(moduleStart, moduleEnd);
return(true);
return(false);
void MD_Parola::displayZoneText(uint8_t z, const char *pText, textPosition_t align, uint16_t speed, uint16_t pause, textEffect_t effectIn, textEffect_t effectOut)
setTextBuffer(z, pText);
setTextAlignment(z, align);
setSpeed(z, speed);
setPause(z, pause);
setTextEffect(z, effectIn, effectOut);
displayReset(z);
bool MD_Parola::displayAnimate(void)
bool b = false;
// suspend the display while we animate a frame
_D.update(MD_MAX72XX::OFF);
for (uint8_t i = 0; i < _numZones; i++)
b |= _Z[i].zoneAnimate();
// re-enable and update the display
_D.update(MD_MAX72XX::ON);
return(b);
size_t MD_Parola::write(const char *str)
// .print() extension of a string
displayText((char *)str, getTextAlignment(), 0, 0, PA_PRINT, PA_NO_EFFECT);
while (displayAnimate())
/* do nothing */;
return(strlen(str));
size_t MD_Parola::write(const uint8_t *buffer, size_t size)
char *psz = (char *)malloc(sizeof(char) * (size + 1));
if (psz == nullptr) return(0);
memcpy(psz, buffer, size);
psz[size] = '\0';
write(psz);
free(psz);
return(size);
The error-log
Arduino: 1.8.19 (Windows 10), TD: 1.58, Board: "Arduino Uno"
C:\Arduino-Pure-Portable\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\hardware -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -tools C:\Arduino-Pure-Portable\arduino-1.8.19\tools-builder -tools C:\Arduino-Pure-Portable\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -libraries C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687 -warnings=none -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_959978 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino
C:\Arduino-Pure-Portable\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\hardware -hardware C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -tools C:\Arduino-Pure-Portable\arduino-1.8.19\tools-builder -tools C:\Arduino-Pure-Portable\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages -libraries C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687 -warnings=none -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_959978 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino
Using board 'uno' from platform in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\sketch\\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino.cpp" -o nul
Alternatives for MD_MAX72xx.h: [MD_MAX72XX@3.3.1]
ResolveLibrary(MD_MAX72xx.h)
-> candidates: [MD_MAX72XX@3.3.1]
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\sketch\\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\sketch\\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino.cpp" -o nul
Alternatives for MD_Parola.h: [MD_Parola@3.7.3]
ResolveLibrary(MD_Parola.h)
-> candidates: [MD_Parola@3.7.3]
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\sketch\\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino.cpp" -o nul
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_MAX72XX\src\MD_MAX72xx.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_MAX72XX\src\MD_MAX72xx_buf.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_MAX72XX\src\MD_MAX72xx_font.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_MAX72XX\src\MD_MAX72xx_pix.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_PZone.cpp
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola.cpp" -o nul
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola_Blinds.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola_Close.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola_Diag.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola_Dissolve.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola_Fade.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola_Grow.cpp
Using cached library dependencies for file: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola_HScroll.cpp
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Mesh.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Open.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Print.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Random.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Scan.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Slice.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Sprite.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_VScroll.cpp" -o nul
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Wipe.cpp" -o nul
Generating function prototypes...
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\sketch\\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\sketch\\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\sketch\\Arduino-Uno-Timer-ISR-one-button-Stop-wtach-start-stop-reset-ch.ino.cpp.o"
Compiling libraries...
Compiling library "MD_MAX72XX"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_MAX72XX\MD_MAX72xx_buf.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_MAX72XX\MD_MAX72xx_pix.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_MAX72XX\MD_MAX72xx.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_MAX72XX\MD_MAX72xx_font.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\SPI\SPI.cpp.o
Compiling library "MD_Parola"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola.cpp.o"
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_PZone.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_Parola_Diag.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_Parola_Grow.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_Parola_Blinds.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_Parola_Close.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_Parola_Dissolve.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_Parola_HScroll.cpp.o
Using previously compiled file: C:\Users\dipl-\AppData\Local\Temp\arduino_build_146687\libraries\MD_Parola\MD_Parola_Fade.cpp.o
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Open.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_Open.cpp.o"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Print.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_Print.cpp.o"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Random.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_Random.cpp.o"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Sprite.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_Sprite.cpp.o"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Scan.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_Scan.cpp.o"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Mesh.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_Mesh.cpp.o"
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_Slice.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_Slice.cpp.o"
C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola\src\MD_Parola.cpp: In member function 'bool MD_Parola::begin(uint8_t)':
"C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_MAX72XX\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src" "C:\\Arduino-Pure-Portable\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MD_Parola\\src\\MD_Parola_VScroll.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_146687\\libraries\\MD_Parola\\MD_Parola_VScroll.cpp.o"
Using library MD_MAX72XX at version 3.3.1 in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_MAX72XX
Using library SPI at version 1.0 in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\packages\arduino\hardware\avr\1.8.6\libraries\SPI
Using library MD_Parola at version 3.7.3 in folder: C:\Arduino-Pure-Portable\arduino-1.8.19\portable\sketchbook\libraries\MD_Parola
exit status 1
Error compiling for board Arduino Uno.
As far as I have started to research on that error. This error occures if you define a function void but want to return a value. In this cas the function is defined bool
I do not yet understand what the compiler does not like
As opposed to the 'war of cake'? Must have been a sweet truce!
Or was it like a treaty that only lasted while dessert was served?
LOL !
I was looking for the peace-logo in the smileys but did not find not even a "piece" of it
here you go ( (it's an emoji)
