Need some programming help for making my digital ledstrip react to music.
Hello,
I'm working on a project to get light to react to music. A max sketch I found monitors the outgoing sound on my pc and sends data about it (low, mid and high frequencies) to my arduino over serial connection. The Arduino is programmed to receive this data and turn (it doesn't only fully turn the leds on or off, but it uses pwm to adjust the brightness.) on 6 leds. (one for low, mid and high frequencies in stereo). This is the code the Arduino uses:
//  Stereo Color Organ (Receiver)
//  Collin Cunningham - Makezine.com
//  http://blog.makezine.com/archive/2010/11/powerleds
//    - For controlling six LEDs via a serial connection
//    - Listens for a six ASCII value message sent over serial,
//      and parses those messages with the Arduino Messenger library:
//      http://www.arduino.cc/playground/Code/Messenger
//      ... then uses the values to set pins 3, 5, 6, 9, 10, 11 accordingly.
//    - Each message is composed of 6 ASCII values ranging from 0-255,
//      values are seperated by a single space and the entire message
//      completed with a carriage return.
//      Example:  135 20 234 189 55 255 (carriage return == ASCII code 13)
//    - Any value over 255 is redefined as a random value between 0-255
//    - Values are inverted for use with 2 of SparkFun's ZXLD1360 LED Driver boards
//      Inversion can be disabled by removing the second line of the processValue function:
//      else { value = map(value,0,255,255,0); }
//include and initialize the Messenger library for parsing ASCII messages
#include <Messenger.h>
Messenger message = Messenger();
//define our PWM output pins
int HighL = 3;
int MidL = 5;
int LowL = 6;
int HighR = 9;
int MidR = 11;
int LowR = 10;
//create variables for our output values
int highValLeft, midValLeft, lowValLeft;
int highValRight, midValRight, lowValRight;
        //set our PWM pins as outputs
	pinMode(HighL, OUTPUT);
	pinMode(MidL, OUTPUT);
	pinMode(LowL, OUTPUT);
        pinMode(HighR, OUTPUT);
	pinMode(MidR, OUTPUT);
	pinMode(LowR, OUTPUT);
        //set them all to Low, initially
	digitalWrite(HighR, LOW);
	digitalWrite(MidR, LOW);
	digitalWrite(LowR, LOW);
	digitalWrite(HighL, LOW);
	digitalWrite(MidL, LOW);
	digitalWrite(LowL, LOW);
        //Begin serial connection for receiving values and tell 'em we're ready
	Serial.println("READY");
        //associate an action for messages handled by Messenger library
	message.attach(messageReady);
void loop()  {
        //when there's new serial data available,
        //process it with the Messenger library
	while ( Serial.available() ) { message.process( Serial.read () );}
void messageReady(){
        //use values from serial data to define the output values
	while (message.available()) {
		highValLeft  = message.readInt();
		midValLeft   = message.readInt();
		lowValLeft   = message.readInt();
                highValRight = message.readInt();
		midValRight  = message.readInt();
		lowValRight  = message.readInt();
                //write the above variables to the output pins
		writeLEDs();
void writeLEDs(){
	//write the LED values inverted for the left channel
	analogWrite( HighL, processValue(highValLeft) );
	analogWrite( MidL,  processValue(midValLeft) );
	analogWrite( LowL,  processValue(lowValLeft) );
        //write the LED values inverted for the right channel
        analogWrite( HighR, processValue(highValRight) );
	analogWrite( MidR,  processValue(midValRight) );
	analogWrite( LowR,  processValue(lowValRight) );
int processValue(int value){
        //any value over 255 is replaced with a random value between 0-255
	if (value > 255) value = random(0,255);
	return value;
This all works fine, but I really would like to use my digital ledstrip instead of 6 little leds. I have a 1 meter digital neopixel RGB ledstrip from adafruit. (Adafruit NeoPixel Digital RGB LED Strip - White 30 LED [WHITE] : ID 1376 : $84.75 : Adafruit Industries, Unique & fun DIY electronics and kits) This is where I really need some help, my programming skills just aren't good enough to program my Arduino so that it fades all the blue, red and green leds in my ledstrip on and off.
Some basic code for my ledstrip to make it do some example stuff. Maybe it helps?
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_RGB     Pixels are wired for RGB bitstream
//   NEO_GRB     Pixels are wired for GRB bitstream
//   NEO_KHZ400  400 KHz bitstream (e.g. FLORA pixels)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Some example procedures showing how to display to the pixels:
  colorWipe(strip.Color(255, 0, 0), 50); // Red
  colorWipe(strip.Color(0, 255, 0), 50); // Green
  colorWipe(strip.Color(0, 0, 255), 50); // Blue
  rainbow(20);
  rainbowCycle(20);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
   WheelPos -= 170;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Thanks a lot in advance.
Unless I'm missing something, this should be trivial. The strip.setPixelColor() method allows you to assign a color to each LED. The only challenge is what color to assign to each LED.
You are currently getting 6 values, 3 for each of two channels, from the PC. If you have two strips, one for each channel, then replacing the code in writeLEDs() to assign the same color to each pixel on each channel should be pretty easy.
If you want to do something different, explain that better.
Hello,
int HighL = 3;
int MidL = 5;
int LowL = 6;
int HighR = 9;
int MidR = 11;
int LowR = 10;
void loop()  {
		writeLEDs();
void writeLEDs(){
	return value;
#define PIN 6
  strip.begin();
  rainbow(20);
  rainbowCycle(20);
      strip.show();
      delay(wait);
  uint16_t i, j;
    strip.show();
    delay(wait);
  uint16_t i, j;
    strip.show();
    delay(wait);
  if(WheelPos < 85) {
   WheelPos -= 85;
   WheelPos -= 170;
Unless I am very much mistaken then answer is here
http://forum.arduino.cc/index.php?topic=185921.0;topicseen
Cross posting is a big no no on this forum, do not do it.
Topics merged.
Cross-posting wastes time.
DO NOT CROSS-POST.
First of all, I'm really sorry for the cross-posting. I thought I had placed my topic in the wrong forum.
PaulS:
Thanks for the help but I still can't get it to work. I tried replacing some things in the code like you said but it is all so complicated. Could you please explain to me what I have to do?
