Is there a way to over ride the pins used by the I2C (wire.lib)? Currently A4 and A5 are used. In my sketch A4 is being used in another lib. I would like to assign A6 to replace it, but only in this sketch.
Any help would be much appreciated.
Babak
These pins are hardware defined. What you are looking for is a software I2C library. This question has come up before - apparently without resolution: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1271150861
Thanks Mark, did not realize the I2C was driven by hardware. I'll have to change the LCD driver to get it off the A4 pin.
Thanks again, Babak
There is a software i2c library - softi2cmaster - but it would be best to use the hardware lines and move the LCD.
