Hi ...
I HOPE THAT YOU ARE DOING WELL.
I just want to add a brake/stop (NEUTRAL) for one or two seconds when the two BLDC motors will move from forward to reverse and vice versa. I tried to make changes but nothing works; Also I am not good in a coding.
Here is the code: Please check it
#include <Servo.h>
const int m_1 = 2; //CHANGE THE PIN TO 5
const int m_2 = 3; //CHANGE THE PIN TO 6
const int LED = 13;
// BATTERY READINGS VARIABLES
const int Battery = A0;
float Voltage = 0.0; // input battery voltage
float Voltage1 = 0.0; // output voltage for analog pin A0
float R1 = 1581; // R1 1581, 1597
float R2 = 1000; // R2 1000, 1000
int readValue = 0;
long previousMillis_battery = 0;
byte Bat_start_timer = 0;
unsigned long battery_wait = 0;
unsigned long currentMillis = 0; // VALID FOR ALL FUNCTIONS(COUNTER)
// BATTERY FUNCTION
void battery() {
readValue = analogRead(Battery);
Voltage1 = readValue * (5.0 / 1023.0);
Voltage = Voltage1 / (R2 / (R1 + R2));
if (Bat_start_timer == 0)
battery_wait = 60000;
if (currentMillis - previousMillis_battery > battery_wait) {
Serial.print("$ABC,"); Serial.print(Voltage); Serial.print("V"); Serial.print('\n');
previousMillis_battery = currentMillis;
Bat_start_timer = 1;
currentMillis = millis(); // to monitor/print voltages on a serial monitor
} // battery FUNCTION END
String strID = "";
int BaudRate = 4800;
Servo ESC_1; // create servo object to control the ESC 1
Servo ESC_2; // create servo object to control the ESC 2
#define FWD 0
#define BWD 1
unsigned int FORWARD = 2000;
unsigned int NEUTRAL = 1500;
unsigned int REVERSE = 1000;
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change:
unsigned int APwm = NEUTRAL;
unsigned int BPwm = NEUTRAL;
boolean ADirection = FWD;
boolean BDirection = FWD;
int CurrentAPwm = NEUTRAL;
int CurrentBPwm = NEUTRAL;
unsigned int AVelocity = 0; // CURRENT VELOCITY OF M1 in 0-100%
unsigned int BVelocity = 0; // CURRENT VELOCITY OF M2 in 0-100%
String inputString = ""; //a string to hold incoming data
int TaskNumber = 0;
// FOR 2-SECONDS TIMER
uint32_t msgTimeout = 0ul;
uint32_t timeNow;
unsigned int GetValue(void)// fetch three digit number value from received string and convert to INTEGER
unsigned int Val = 0;
Val = (inputString[3] - 48) * 100;
Val = Val + (inputString[4] - 48) * 10;
Val = Val + (inputString[5] - 48);
return (Val);
Serial.begin(BaudRate);
ESC_1.attach(m_1);// (pin, min pulse width, max pulse width in microseconds)
ESC_2.attach(m_2);// (pin, min pulse width, max pulse width in microseconds)
pinMode(LED, OUTPUT);
pinMode(Battery, INPUT);
Serial.println("ABC System Started");
ESC_1.writeMicroseconds(APwm);
ESC_2.writeMicroseconds(BPwm);
boolean AFwdFlag = 0; // makes sure that the serial only prints once the state
boolean BFwdFlag = 0;
// battery-send
static int runit;
if (runit == 1000) {
battery();
runit = 0;
runit++;
// 2 SECONDS TIMER CODE STARTS
timeNow = millis();
serialEvent();
if (TaskNumber == 0) {
// if we've gone 2-seconds...
if ((timeNow - msgTimeout) >= 2000ul)
APwm = NEUTRAL;
BPwm = NEUTRAL;
} // if
} // if
if (TaskNumber) {
// each pass where we see a non-zero task #, reset the msgTimeout value
msgTimeout = millis();
digitalWrite(LED, LOW);
if (TaskNumber) {
if (TaskNumber == 1) Serial.println("OK");
if (TaskNumber == 2 || TaskNumber == 4) {
ESC_1.writeMicroseconds(NEUTRAL);
if (TaskNumber == 3 || TaskNumber == 4) {
ESC_2.writeMicroseconds(NEUTRAL);
// 2 SECONDS TIMER ENDS
if (TaskNumber == 5 || TaskNumber == 7) {
if (ADirection == FWD) {
APwm = NEUTRAL + (((FORWARD - NEUTRAL) / 100) * AVelocity);
AFwdFlag = 1;
else {
if (AFwdFlag == 1)
// Need help to make some changes here to make motor A stop for 2 seconds when moving from forward to reverse and vice versa.
ESC_1.writeMicroseconds(NEUTRAL); delay(100);
ESC_1.writeMicroseconds(REVERSE); delay(100);
AFwdFlag = 0;
APwm = NEUTRAL - (((NEUTRAL - REVERSE) / 100) * AVelocity);
if (TaskNumber == 6 || TaskNumber == 7) {
if (BDirection == FWD) {
BPwm = NEUTRAL + (((FORWARD - NEUTRAL) / 100) * BVelocity);
BFwdFlag = 1;
else {
if (BFwdFlag == 1)
// Need help to make some changes here to make motor B stop for 2 seconds when moving from forward to reverse and vice versa.
ESC_2.writeMicroseconds(NEUTRAL); delay(100);
ESC_2.writeMicroseconds(REVERSE); delay(100);
BFwdFlag = 0;
BPwm = NEUTRAL - (((NEUTRAL - REVERSE) / 100) * BVelocity);
TaskNumber = 0;
//Increment and Decrement for both motors
if (APwm > CurrentAPwm)
CurrentAPwm ++;
ESC_1.writeMicroseconds(CurrentAPwm);
if (APwm < CurrentAPwm)
CurrentAPwm --;
if (BPwm > CurrentBPwm)
CurrentBPwm ++;
ESC_2.writeMicroseconds(CurrentBPwm);
if (BPwm < CurrentBPwm)
CurrentBPwm --;
} //end
// <AN> <A+xxx> <A-xxx>
// <BN> <B+xxx> <B-xxx>
// <CN> <C+xxx> <C-xxx>
void serialEvent() {
while (Serial.available()) { //while a char is holding in the serial buffer //get the new char
char inChar = (char)Serial.read(); //get the character we just received
inputString += inChar; //add it to the inputString
if (inChar == '\r' || inChar == 10) //if the incoming character is a Carriage Return \ //set the flag
if (inputString[0] == '<')
if (inputString[1] == 'A' && inputString[2] == 'T' && inputString[3] == '>' ) TaskNumber = 1; // AT
if (inputString[2] == 'N' && inputString[3] == '>' )
if ( inputString[1] == 'A') TaskNumber = 2; // Set Motor A to Neutral
if ( inputString[1] == 'B') TaskNumber = 3; // Set Motor B to Neutral
if ( inputString[1] == 'C') TaskNumber = 4; // Set Both Motors to Neutral
if (inputString[6] == '>' )
if ( inputString[1] == 'A') {
if (inputString[2] == '+') ADirection = FWD; else ADirection = BWD;
AVelocity = GetValue();
TaskNumber = 5;
if ( inputString[1] == 'B') {
if (inputString[2] == '+') BDirection = FWD; else BDirection = BWD;
BVelocity = GetValue();
TaskNumber = 6;
if ( inputString[1] == 'C') {
if (inputString[2] == '+') {
ADirection = FWD;
BDirection = FWD;
else {
ADirection = BWD;
BDirection = BWD;
TaskNumber = 7;
inputString = ""; //clear the string
