Hi all, I’ve been having issues trying to get a NEO 6M GPS to talk to my Arduino UNO.
I’m using Arduino 1.0.5
Here is the gps data sheet
Here is the latest code I’ve tried
#include <SoftwareSerial.h>
#define RXPIN 8 // From the GPS to the Arduino
#define TXPIN 10
SoftwareSerial mySerial(RXPIN, TXPIN);
Serial.begin(57600);// old 57600 New 115200
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(9600); // old 4800 new 57600
mySerial.println("Hello, world?");
void loop() // run over and over
//mySerial.listen();
//Serial.print(mySerial.available() + "\n");
if (mySerial.available()>0){
byte c = mySerial.read();
Serial.print(c + "\n");
delay(100);
Hi PaulS,
Thanks for the reply. I’m quite new to the Arduino so most of the code I’ve been using is cut and paste.
I have removed the println to the GPS, I guess it was just causing extra noise?
How should I be adding a carriage return?
oops, made a mistake when I paste the code, c was a char.
I’ve made a few changes, uploaded and copied the response. Still nothing like what I want.
The new code
#define TXPIN 10
char c = mySerial.read();
Serial.print(c);
delay(100);
the output
Goodnight moon!
4Öï"ÿÿ^ß{ï!
etc. etc. etc.
If c was a byte it outputs numbers if that is any help.
That’s what the println() method does (as opposed to the print() method).
None of the above. Useless comments are worse than no comments.
Are you sure that the GPS communicates at 9600 baud? Is the Serial Monitor set to 115200?
Serial.print(c);
delay(100);
Read a character, if one is available, and print it. Wait forever, and repeat. No, not a good idea.
The if statement should be a while statement. The delay() is useless in either case. There is data to be read, as fast as possible, or there isn’t. Sitting on your thumbs for a while, in either case, is useless.
PaulS:
of course, silly me.
PaulS:
useless comments removed.
PaulS:
I have used the u-center software and a FTDI to make sure the GPS actually work and the u-center software is saying 9600 baud.
The serial Monitor is set to 57600 baud
PaulS:
I’ve updated the code to use a while loop and removed the delay. This is probably the closest I’ve seen to the output I want. There is still a lot of gibberish but I can see some lines that look right.
here is the updated code
#define TXPIN 10
while(mySerial.available()>0){
Serial.print(c);
Does the good data match what you see when the device is connected via the FTDI cable to the PC?
Is there a relationship between the "garbage" and something that is missing (if anything is missing) from the output via the FTDI cable using the u-center application?
PaulS:
Yeah, it’s a good match without the garbage. (see text console attached)
PaulS:
Is there a relationship between the “garbage” and something that is missing (if anything is missing) from the output via the FTDI cable using the u-center application?
When I open the Binary Console in u-center I can see output that is similar to the garbage around the useful info so I assume there is something I need to filter out?
There may be a way to configure the GPS to simply not send that data.
Any idea how that would be?
I connected to the GPS through the UNO and it almost displays the correct information, but not enough to be useful. Anything else you think of that might be able to help?
My U-Blox 6 defaults at 4800 baud and quite well at that, although I did try once to re-program it to a higher baud rate (56.7K) but the programmming went away whhen I dispowered it... What ever you were displaying from the GPS looks like it is read at the wrong baud rate. What you see in the U-Blox binary window has Nothing to do with the NMEA serial data stream being sent by the GPS device... It is also VERY possible that you might need to put the receiver closer to a wondow because that bad data you are seeing could be bad reception, Although I saw one GPRMC message I couldn't see all of it as it ws garbled possibly due to your code, try TinyGPS12 by Mikal hart for better information sketches and libraries.
