srnet:
At the signal strengths indicated, its unlikley to get a fix at all.
That's a valid comment, Stewart. However, I've had the situation where the board does not get a fix all day and gets a fix the next day. In the same position.
I also get the situation where several sats give strong signals but the receiver still does not get a fix.
One thing tho, it does work consistently well sitting on the dash of my car.
At this point, I'd suspect either the hardware or some kind of interference. If you're testing at work maybe there's something transmitting on a frequency that's messing with the GPS, deliberately or not. Can you get a position with a GPS equipped cell phone? Don't forget that the phone may estimate its position from nearby cell towers if it can't get a GPS fix.
Maybe try taking your kit some miles away and try again.
wildbill:
I tried at night because of high quality. So, there was no sunspot. I think this module is powerless for my location. I think I will try a new module with a bigger antenna. Thanks for your helps
