So I have been fighting with the DUE both real and copies (2 boards) with the latest version of the IDE from Window 10 apps.
I am using the Sparkfun QWIIC connector system.
I am trying to run the Example_3 Get Position from the Spark fun u blox library.
The M8U and a Nano 33 IOT work great together on WIRE.
The DUE and a Sparkfun Serial LCD/Sparkfun External_EEPROM, and Adafruit BMP390L all work great. No problems on either WIRE or WIRE1.
So with the same wiring/connector as used above that worked fine at both 100K and 400K with the other components, it does not work with the M8U.
The M8U says it has internal pull ups but I mesure and open between the 3.3 and the SDA/SCL. I read there is issue with the WIRE pull up so I removed them from the board. Did not work. I added 4.7K, which did not work. But the WIRE original pull ups and the 4.7K work fine for the other QWIIC based components.
So the long and the short of it is the M8U and the DUE WIRE do not like each other.
Any ideas why it is just these two?
Thanks
Bruce
