#include <Arduino.h>
#include <NMEAGPS.h>
// Program: NMEAlocDMS.ino
// Description: This program only parses an RMC sentence for the lat/lon.
// Prerequisites:
// 1) NMEA.ino works with your device (correct TX/RX pins and baud rate)
// 2) The RMC sentence has been enabled.
// 3) Your device sends an RMC sentence (e.g., $GPRMC).
// Serial is for trace output to the Serial Monitor window.
// License:
// Copyright (C) 2014-2017, SlashDevin
// This file is part of NeoGPS
// NeoGPS is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// (at your option) any later version.
// NeoGPS is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with NeoGPS. If not, see <http://www.gnu.org/licenses/>.
#include <GPSport.h>
// Check that the config files are set up properly
#if !defined( NMEAGPS_PARSE_RMC )
#error You must uncomment NMEAGPS_PARSE_RMC in NMEAGPS_cfg.h!
#endif
#if !defined( GPS_FIX_LOCATION_DMS )
#error You must uncomment GPS_FIX_LOCATION_DMS in GPSfix_cfg.h!
#endif
#ifdef NMEAGPS_INTERRUPT_PROCESSING
#error You must *NOT* define NMEAGPS_INTERRUPT_PROCESSING in NMEAGPS_cfg.h!
#endif
static NMEAGPS gps; // This parses the GPS characters
static void doSomeWork( const gps_fix & fix );
// This is the best place to do your time-consuming work, right after
// the RMC sentence was received. If you do anything in "loop()",
// you could cause GPS characters to be lost, and you will not
// get a good lat/lon.
// For this example, we just print the lat/lon. If you print too much,
// this routine will not get back to "loop()" in time to process
// the next set of GPS data.
if (fix.valid.location) {
DEBUG_PORT << fix.latitudeDMS;
DEBUG_PORT.print( fix.latitudeDMS.NS() );
DEBUG_PORT.write( ' ' );
if (fix.longitudeDMS.degrees < 100)
DEBUG_PORT.write( '0' );
DEBUG_PORT << fix.longitudeDMS;
DEBUG_PORT.print( fix.longitudeDMS.EW() );
// No valid location data yet!
DEBUG_PORT.print( '?' );
DEBUG_PORT.println();
} // doSomeWork
static void GPSloop();
while (gps.available( gpsPort ))
doSomeWork( gps.read() );
} // GPSloop
pinMode(5, OUTPUT); // GPS PIN
digitalWrite(5, LOW);//GPS ON
delay(100);
DEBUG_PORT.begin(9600);
while (!DEBUG_PORT)
DEBUG_PORT.print( F("NMEAlocDMS.INO: started\n") );
DEBUG_PORT.println( F("Looking for GPS device on " GPS_PORT_NAME) );
DEBUG_PORT.flush();
gpsPort.begin(9600);
GPSloop();
