So the aim of my code is to have two NeoPixel rings light up while slowly rising in brightness from 0 to 255 when the button is pressed. So in the code I have, I made a variable called "mode" where it reads the value of mode when the button is pressed. The value of mode will execute a function that determines what the NeoPixels show.
The first problem I have with my current code is that once the NeoPixels light up at maximum brightness, it seems to redo the 0 -> 255 brightness thing again (and it keeps on going).
The second problem is that when I click on the button again after I activate the light mode, it sometimes doesn't respond and doesn't change to the other mode.
#define LED_PIN_A 5
#define LED_PIN_B 6
#define LED_COUNT 24
Adafruit_NeoPixel stripA(LED_COUNT, LED_PIN_A, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel stripB(LED_COUNT, LED_PIN_B, NEO_GRB + NEO_KHZ800);
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = LOW; // variable for reading the pushbutton status
int lastButtonState = LOW;
int mode = 0;
void off() {
stripA.clear();
stripB.clear();
for(int i = 0; i < LED_COUNT; i++) {
stripA.setPixelColor(i,0,0,0);
stripB.setPixelColor(i,0,0,0);
stripA.show();
stripB.show();
void on() {
for(int x = 0; x < 256; x++) {
stripA.setPixelColor(i,x,x,x);
stripB.setPixelColor(i,x,x,x);
stripA.show();
stripB.show();
delay(15);
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
stripA.begin();
stripB.begin();
buttonState = digitalRead(buttonPin);
lastButtonState = buttonState;
stripA.clear();
stripB.clear();
if (lastButtonState == LOW && buttonState == HIGH) {
mode = mode + 1;
if(mode > 1) {
mode = 0;
Serial.print(mode);
if(mode == 0) {
off();
else if(mode == 1) {
on();
