The standard design pattern for a finite state machine can produce very clear and simple to follow code even for complex real world problems. These are normally implemented as a switch statement and the cases represent the states.
The phasing is so that the case statement for the precursor state sets up the initial conditions for the successor state (switching a led or relay on etc.). That is, when a case statement is entered for a particular state, that state is already active. This would be clear if you attempt to write debug message at the beginning of the case statement and see that it is printed continuously. Anyway, this model is usually fine for the majority of applications.
However, it does sometimes mean that dummy or minor states have to added. For example, if the application includes an external event and that external event can only be processed after a pause, then a dummy buffer state has to be added to implement the pause.
Here is an example of a simple state machine, a button controlled mixer, which waits on an external event, in this case a button press, and requires a pause before starting the mixer motor.
Wait for button press
Wait an additional 1 second and start the mixer motor
Quit after 5 seconds, switching off the motor and back to the start.
The state diagram is something like this:
The code is here https://wokwi.com/projects/455398703321183233
Code
const int button = 4 ;
const int mixerPin = 5 ;
enum class States { WAIT_BUTTON_PRESS, WAIT_BUFFER, IN_MIX } ;
States state = States::WAIT_BUTTON_PRESS ;
uint32_t stateTimer = millis() ;
pinMode( button, INPUT_PULLUP) ;
pinMode( mixerPin, OUTPUT) ;
switch ( state ) {
case States::WAIT_BUTTON_PRESS :
if ( !digitalRead( button ) ) {
state = States::WAIT_BUFFER ;
break ;
case States::WAIT_BUFFER :
if ( millis() - stateTimer > 1000 ) {
state = States::IN_MIX ;
digitalWrite( mixerPin, HIGH ) ;
break ;
case States::IN_MIX :
if ( millis() - stateTimer > 5000 ) {
digitalWrite( mixerPin, LOW ) ;
break ;
The dummy wait states are, of course, simple to implement but can cause clutter that has to be shown in the state diagram.
This design pattern can be extended with an addition to eliminate the need for these dummy states. This, however, requires an addition to the standard design pattern so that, on the new entry to the case statement implementing the state, a variable can be read indicating that this is indeed a new entry. Hence, it can then do its own initialisation. That is at the end of the precursor state there is no longer any setup for the next state. Using this method, the above application could be implemented as follows, dropping the dummy wait:
Wait for button press and pause 1 second
Start mixer motor, run for 5 seconds and return to start.
The code is here https://wokwi.com/projects/455398738491473921
Code
Nested state example.
Here a variable is set on change of state so the successor state logic can
enum class States { WAIT_BUTTON_PRESS_DELAYED, IN_MIX } ;
States state = States::WAIT_BUTTON_PRESS_DELAYED ;
bool stateChangeNew = true ; // indicating a new entry to state
switch ( state ) {
case States::WAIT_BUTTON_PRESS_DELAYED : {
enum class StatesIntern { INIT, WAIT_BUTTON_PRESS, WAIT_BUFFER_TIME } ;
static StatesIntern stateIntern ;
static uint32_t stateTimerIntern = 0 ;
if (stateChangeNew) {
stateChangeNew = false ; // reset
Serial.println("we are new in state WAIT_BUTTON_PRESS_DELAYED so initialise") ;
stateIntern = StatesIntern::WAIT_BUTTON_PRESS ;
stateTimerIntern = millis() ;
switch ( stateIntern ) {
case StatesIntern::WAIT_BUTTON_PRESS :
Serial.println("button press detected. Pausing.") ;
stateIntern = StatesIntern::WAIT_BUFFER_TIME ;
break ;
case StatesIntern::WAIT_BUFFER_TIME :
if ( millis() - stateTimerIntern > 1000 ) {
break ;
break ;
Serial.println("we are new in state IN_MIX so initialise") ;
Serial.println("terminating and back to start") ;
break ;
The pattern has been extended so that a state in a state machine can itself contain an entire state machines, nested like a Russian doll.
I avoided including functions or adding classes to keep the example simple, or at least at a single level. However, it is clear that on a larger implementation, some parts could be made less verbose by adding a function. For example, a change of state involves setting a state timer and also a variable to indicate a new state and a function call removes the repetition. A class could also be used to wrap the state variables together with the function(s) for maintaining them.
One (other) advantage of this model is that it is much easier to add debug messages when in the state itself using the initialisation routine.
Maybe someone finds it interesting or useful.
