New arduino user, seeking guidance on thermostat project
I'm looking to build my own thermostat with multiple temp sensors and lcd with buttons. I have never done anything with the arduino unit however I know multiple people have done this exact thing. The code I hope to write most of it my self. I want to start getting some hardware but i'm not sure what all to get to start with. Here is what I plan on doing:
-finished project will be ethernet connected
-control HVAC/Fan/Heat
-run on a schedule
-log power on/power off of hvac fan heat as well as the temp of the house either onboard or to an external server or both
-3 seperate temp in 3 rooms and average the temp for a better reading
-LCD with ~2 buttons (maybe a switch to shut off all cooling/heating) to display current stats as well as temp change to override schedule.
-an alternative is an LCD screen with a touchscreen overlay as the interface
~pull power from current line for power and save settings to eprom but have a battery in case of power failure
This is what I have questions about:
-Will I need more than one arduino unit?
-What kind of unit(s) will I need?
-Should I go with a larger unit to allow for a small web server (not sure what the limitations of the arduino are)?
Make a plan and do one step at the time.
Start with spending one evening at the tutorial and reference section working through the examples, you will learn a lot from it and you will find usable pieces of code there.
Check out - Data-Logger Shield for Arduino - it can give you some ideas
  1. No it is doable with a UNO
  2. UNO
  3. no not needed, however a Mega is fun too.
