Initial Releases v1.0.0
- Initial coding to support AVR boards, such as Mega-2560, UNO, Nano, Leonardo, etc., using AVR cores
- The hardware-based PWM channels can generate very high frequencies.
Debug Terminal Output
1. PWM_Waveform on Arduino AVR Mega2560
The following is the sample terminal output when running example PWM_Waveform on AVR Mega2560, to demonstrate how to use the setPWM_manual() function in wafeform creation
Starting PWM_Waveform on Arduino AVR Mega2560/ADK
AVR_PWM v1.0.0
[PWM] AVR_PWM: _dutycycle = 0
[PWM] setPWM: _dutycycle = 0
[PWM] setPWM_Int: _dutycycle = 0
[PWM] setPWM_Int:using TIMER4C
[PWM] setPeriod_Timer4: F_CPU = 16000000 , cycles = 8000
[PWM] setPeriod_Timer4: clockSelectBits = 1 , pwmPeriod = 8000
[PWM] setPWM_Int:using TIMER4C, _dutycycle = 0
Actual data: pin = 8, PWM DutyCycle = 0.00, PWMPeriod = 8000.00, PWM Freq (Hz) = 1000.0000
[PWM] PWM enabled, DCValue = 0 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 1000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 1500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 2000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 2500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 3000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 3500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 4000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 4500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 5000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 5500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 6000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 6500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 7000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 7500 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
[PWM] PWM enabled, DCValue = 8000 , pwmPeriod = 8000 , _frequency = 1000.00 , _actualFrequency = 1000.00
2. PWM_Waveform on Arduino AVR ATMega32U4
The following is the sample terminal output when running example PWM_Waveform on ATMega32U4, to demonstrate how to use the setPWM_manual() function in wafeform creation
Starting PWM_Waveform on Arduino AVR ATMega32U4
AVR_PWM v1.0.0
[PWM] setPWM_Int:using TIMER1A
[PWM] setPeriod_Timer1: F_CPU = 16000000 , cycles = 8000
[PWM] setPeriod_Timer1: clockSelectBits = 1 , pwmPeriod = 8000
Actual data: pin = 9, PWM DutyCycle = 0.00, PWMPeriod = 8000.00, PWM Freq (Hz) = 1000.0000
3. PWM_Waveform on Arduino AVR Nano
The following is the sample terminal output when running example PWM_Waveform on AVR Nano, to demonstrate how to use the setPWM_manual() function in wafeform creation
Starting PWM_Waveform on Arduino AVR UNO, Nano, etc.
AVR_PWM v1.0.0
[PWM] setPWM_Int:using TIMER1B
Actual data: pin = 10, PWM DutyCycle = 0.00, PWMPeriod = 8000.00, PWM Freq (Hz) = 1000.0000
4. PWM_DynamicDutyCycle on Arduino AVR Mega2560
The following is the sample terminal output when running example PWM_DynamicDutyCycle on AVR Mega2560, to demonstrate the ability to provide high PWM frequencies and ability to change DutyCycle on-the-fly.
Starting PWM_DynamicDutyCycle on Arduino AVR Mega2560/ADK
AVR_PWM v1.0.0
[PWM] AVR_PWM: _dutycycle = 32767
[PWM] setPWM_Int: _dutycycle = 32767
[PWM] setPeriod_Timer4: F_CPU = 16000000 , cycles = 1600
[PWM] setPeriod_Timer4: clockSelectBits = 1 , pwmPeriod = 1600
[PWM] setPWM_Int:using TIMER4C, _dutycycle = 799
Change PWM DutyCycle to 90.00
[PWM] setPWM: _dutycycle = 58981
[PWM] setPWM_Int: _dutycycle = 58981
[PWM] setPWM_Int:using TIMER4C, _dutycycle = 7199
Actual data: pin = 8, PWM DC = 89.99, PWMPeriod = 8000.00, PWM Freq (Hz) = 1000.0000
Change PWM DutyCycle to 10.00
[PWM] setPWM: _dutycycle = 6553
[PWM] setPWM_Int: _dutycycle = 6553
Actual data: pin = 8, PWM DC = 9.99, PWMPeriod = 8000.00, PWM Freq (Hz) = 1000.0000
