I am a newbie to ARDUINO but have been involved in Industrial Process Automation most of my life. I know the processes and devices that are available in the manufacturing world and I am hoping to bring a small piece of it into my indoor grow room with ARDUINO technology.
Being a gearhead and a tech geek with limited experience, automation has always fascinated me. I know there are a number of projects out there related to grow room automation. I will use them whenever I can but I am going to enjoy the experience of trying to create my own.
I have some questions that I hope someone can answer...
I currently take four moisture reading around the periphery of a 20 gallon pot. I take the average of the four readings and if the value is on or below my low moisture limit, I water the plant. My questions are:
Can the four readings be transmitted(hopefully wirelessly) collected, averaged and plotted (in the form of an excel file/graph).
Can the reading, if it falls below the low moisture limit target, initiate a watering cycle.
Can this watering cycle be time based or moisture based? In other words, watering based on time would factor in the volume of water that the plant would receive until you deliver the expected measure of water. Or, if the moisture sensor read a high moisture level reading, it would cause the pump to shut down.
I'm pretty sure the second and third questions are doable but I am really interested in knowing if the first question is possible.
