First of all, I am not making a project or anything complicated. Im just trying to learn electronics. I am trying to find a way to interface a microphone to a speaker. The question is can I directly connect them with wires without any circuit? If I need a circuit can you point me to one? After connecting the microphone to speaker then I want to take the output from microphone and connect to arduino ADC and use analogread() and map() to see the output voltage from microphone.
No once you have sound coming out of a speaker it is not suitable for connecting to an arduino.
Why is it not suitable? For example I connect the microphone to speaker. And also I take a wire out of the microphone output not the speaker and connect to arduino. Will it be ok?
The other reason it is not suitable is because the voltage needed to drive a speaker is a small voltage with large current where as that needed to drive an arduino is a largish voltage (5V peak to peak) with very little current capacity.
Both need an amplifier but of different types.
It is possible to connect the same microphone to two different amplifiers and connect one to a speaker and the other to the arduino.
