Newbie, RTC to show time/date on I2C LCD?
Hello all,
I'm new to Arduino, coding, and electronics (other than being on the end user side). I've taken up Arduino as a new hobby and having a blast with it over the last few weeks but I've hit a snag.
All the projects I've been working and doing serial.print for the results have gone fine. My end goal is to make a nice and inexpensive reef controller so getting my projects to show their output on my LCD is important. For instance, getting the time/date to print on the LCD hasn't worked.
I2C 20x4 LCD:
VCC to 5v
GRD to GRD
SCL to A5
SDL to A4
DS1307 RTC:
VCC to 5v
GRD to GRD
SCL to A5
SDL to A4
Both the RTC and LCD are sharing analog pin 4 and 5 on my Uno which I thought was ok since they are both serial devices(?). Maybe my thought process for the proper pins is wrong?
#include <MD_DS1307.h>
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR 0x27
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
  lcd.begin(16,2);
  lcd.clear();
  lcd.noCursor();
void p2dig(uint8_t v)
// print 2 digits leading zero
  if (v < 10) lcd.print("0");
  lcd.print(v);
char *dow2String(uint8_t code)
  char *str[] = {" Sun", " Mon", " Tue", " Wed", " Thu", " Fri", " Sat"};
  return(str[code-1]);
void printTime()
  lcd.setCursor(0,0);
  lcd.print(RTC.yyyy);
  lcd.print("-");
  p2dig(RTC.mm);
  lcd.print("-");
  p2dig(RTC.dd);
  lcd.setCursor(0,1);
  p2dig(RTC.h);
  lcd.print(":");
  p2dig(RTC.m);
  lcd.print(":");
  p2dig(RTC.s);
  if (RTC.Status(DS1307_12H) == DS1307_ON)
    lcd.print(RTC.pm ? " pm" : " am");
  lcd.print(dow2String(RTC.dow));
  RTC.ReadTime();
  printTime();
  delay(100);
Any help/education on the matter would be greatly appreciated.
Check this post
http://forum.arduino.cc/index.php/topic,38954.0.html
