Newbie! Trouble with compiling code for LED clock
Hello everyone! I am new to arduino but catch on quickly and know how to follow directions but I am stumped with this issue. I am trying to create this LED clock and cannot get the code to compile with no issues. Here is the link to the clock and below is the code I just copied by clicking the button in arduino ide called "Copy error messages" any help and advice would be much appreciated! Thank you all!!
Arduino: 1.8.16 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:13:
C:\Users\Matt\Documents\Arduino\libraries\FastLED\src/FastLED.h:433:25: note: candidate: 'template<EBlockChipsets CHIPSET, int NUM_LANES, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB*, int, int)'
433 | static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Matt\Documents\Arduino\libraries\FastLED\src/FastLED.h:433:25: note: template argument deduction/substitution failed:
clock_main:140:57: error: template argument 2 is invalid
140 | FastLED.addLeds<WS2812B, DATA_PIN, GRB>(LEDs, NUM_LEDS);
C:\Users\Matt\Documents\Arduino\libraries\FastLED\src/FastLED.h:474:25: note: candidate: 'template<EBlockChipsets CHIPSET, int NUM_LANES> static CLEDController& CFastLED::addLeds(CRGB*, int, int)'
474 | static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Matt\Documents\Arduino\libraries\FastLED\src/FastLED.h:474:25: note: template argument deduction/substitution failed:
clock_main:140:57: error: wrong number of template arguments (3, should be 2)
In file included from C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:19:
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino: In lambda function:
Settings.h:6:26: error: 'D5' is not captured
6 | #define COUNTDOWN_OUTPUT D5                   // Output pin to drive buzzer or other device upon countdown expiration
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:269:18: note: in expansion of macro 'COUNTDOWN_OUTPUT'
269 | digitalWrite(COUNTDOWN_OUTPUT, LOW);
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:264:39: note: the lambda has no capture-default
264 | server.on("/countdown", HTTP_POST, {
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\Settings.h:6:26: note: 'D5' declared here
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:107:11: note: in expansion of macro 'COUNTDOWN_OUTPUT'
107 | pinMode(COUNTDOWN_OUTPUT, OUTPUT);
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino: In function 'void loop()':
Settings.h:13:18: error: 'D3' was not declared in this scope
13 | #define MODE_PIN D3 // Push button (white): Change Mode
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:641:33: note: in expansion of macro 'MODE_PIN'
641 | int modeReading = digitalRead(MODE_PIN);
Settings.h:14:16: error: 'D4' was not declared in this scope
14 | #define V1_PIN D4 // Push button (red): Visitor+/Minutes Add button
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:642:31: note: in expansion of macro 'V1_PIN'
642 | int v1Reading = digitalRead(V1_PIN);
Settings.h:16:16: error: 'D7' was not declared in this scope
16 | #define H1_PIN D7 // Push button (yellow): Home+/Countdown start button
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:644:32: note: in expansion of macro 'H1_PIN'
644 | int h1_Reading = digitalRead(H1_PIN);
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino: In function 'void updateCountdown()':
Settings.h:6:26: error: 'D5' was not declared in this scope
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:962:18: note: in expansion of macro 'COUNTDOWN_OUTPUT'
962 | digitalWrite(COUNTDOWN_OUTPUT, HIGH);
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino: In function 'void soundBuzzer(unsigned int)':
C:\Users\Matt\Desktop\3D-LED-Clock-1.00\clock_main\clock_main.ino:983:18: note: in expansion of macro 'COUNTDOWN_OUTPUT'
983 | digitalWrite(COUNTDOWN_OUTPUT, HIGH);
exit status 1
Have you followed the installation process at https://github.com/Resinchem/3D-LED-Clock/wiki/Installation
Have you selected the ESP8266 processor in the tools menu. Do you see the ESP8266 port?
Have you tried to program the simple blink into your ESP8266?
Can you post the code you are trying to compile please. I can't find it in that link.
Maybe this will help. This is where I got the code and other info.
Generic ESP8266 Module is what is selected under tools in the BOARD menu
"Generic ESP8266 Module" doesn't define D0, D1, D2, etc. "NodeMCU 1.0 (ESP-12E Module)" does.
WOW. This is why I love smart people like you. I changed the "BOARD" to the one you mentioned and it complied.
Thank you very much for taking time to help out. :smiley:
