NEWBIE Unknown proxy host blocking the install of libraries
The IDE seems to be looking for library files behind a proxy host that doesn't exist.
It seems to be searching for MaccaroniandCheese as a proxy host, butwthat is a name of my main home SSID!.
I think I must have in error typed it in fof something and now its stuck as a proxy host name under Network Preferences (if I erase it, it won't go away for good.,. and I get this when adding a library;:
Downloading ArduinoMqttClient@0.1.6
Failed to install library: ArduinoMqttClient:0.1.6.
Error: 13 INTERNAL: Can't download library: Get "https://downloads.arduino.cc/libraries/github.com/arduino-libraries/ArduinoMqttClient-0.1.6.zip": proxyconnect tcp: dial tcp: lookup maccaroniandcheese: no such host
you can download it here
and install manually as described in Arduino manual
Which version of the IDE?
Which operating system?
Hi @dbbarron.
This is a known bug:
I will share the workaround for this issue:
  1. Select File > Quit from the Arduino IDE menus if it is running.
  2. Use any text editor to open the file at the following path:
    • Windows:
      C:\Users\<username>\.arduinoIDE\arduino-cli.yaml
    • Linux:
      ~/.arduinoIDE/arduino-cli.yaml
    • macOS:
    :exclamation: The .arduinoIDE folder may be hidden by default by your operating system.
  3. Delete the lines from the file that have this format:
    network:
      proxy: http://pippo:pluto@example.com:1234/
      user_agent_ext: daemon
  4. Save the file.
  5. Start the Arduino IDE.
You should now find that "No proxy" is selected in the "Network" tab of the "Preferences" dialog.
