My Nicla Vision is dead?
Hello, I recently acquired a Nicla Vision, at first it worked excellent in both Arduino IDE as well as OpenMV. I needed to solder pins to the card and after that no IDE recognizes it and the DL2 CHARGE LED stays on and only goes off for a moment every 15 seconds. I would appreciate any help to know if the card is still functional.
Note: The entire pin area is completely clean of soldering.
Please show the clean photo after soldering
Your test indicates that it is not. Check all the solder joints for continuity and bridges to neighboring pads, and fix the problem(s).
Adafruit and Sparkfun have excellent soldering tutorials, with photos to compare.
