I have a trouble with sim800l gps module. First of all i'm using a Lithium Polymer Batery to power the sim800l module.
I connect VCC to baterry's (+) and module's GND to battery's (-). I also connect module's RX to Digital pin 10 and TX to 11.
Using the code below i olny get the message "Initializing..."
Any ideas?
Thank you!
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM800L
SoftwareSerial mySerial(10, 11);
//Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
//Begin serial communication with Arduino and SIM800L
mySerial.begin(9600);
Serial.println("Initializing...");
mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
updateSerial();
mySerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best
updateSerial();
mySerial.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged
updateSerial();
mySerial.println("AT+CREG?"); //Check whether it has registered in the network
updateSerial();
updateSerial();
void updateSerial()
while (Serial.available())
mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
while (mySerial.available())
Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
