No communication from GPS over hardware serial
Hello!
I am using a Sparkfun MG2639 shield and an Arduino Leonardo in a project I am currently working on.
Right now I am trying to connect to the GPS module on the shield using hardware serial on pin 0 and 1, which is available if you solder some jumpers on the back of the shield. The jumpers are properly soldered but when I run my code I recieve
$GPGGA,093952.080,,,,,0,0,,,M,,M,,*44
$GPGSA,A,1,,,,,,,,,,,,,,
from the GPS, then nothing.
This is the code I am currently running. I understand that it wont spit out anything other than gibberish but right now I'm just trying to establish stable communication between the Leonardo and the GPS module on the shield.
#include <SFE_MG2639_CellShield.h>
#include <TinyGPS++.h>
#define GPS_BAUD_RATE 115200 // The GPS Shield module defaults to 9600 baud
// Define the serial monitor port. On the Leonardo this is 'Serial'
//  but on other boards this may be 'SerialUSB'
#define SerialMonitor Serial // e.g. Arduino Leonardo
// Define the harware serial port on pins 0/1. On the Leonardo this is 'Serial1'
//  but on other boards this may be 'Serial'
#define gpsPort Serial1 // e.g. Arduino Leonardo
// See https://www.arduino.cc/en/Reference/Serial to find out which Serial ports
//  you should use in the defines above.
int8_t status;
TinyGPSPlus gps;
  SerialMonitor.begin(115200);
  gpsPort.begin(GPS_BAUD_RATE);
  while(!SerialMonitor);
  while(!gpsPort);
  status = cell.begin();
  if (status <= 0)
    Serial.println("Unable to communicate with shield. Looping");
    while(1)
  while(gpsPort.available()) // If GPS data is available
    SerialMonitor.write(gpsPort.read()); // Send it to the serial monitor
You have stable communication.
You do not have good satellite reception. Check the antenna, move closer to a window, or go outside, away from buildings. The first fix could take 10 minutes or more.
Be sure to look at the Troubleshooting section of my NeoGPS library. Lots of other tips there. NeoGPS is smaller, faster and more accurate than all other libraries.
Cheers,
/dev
