No I2C devices found
Hello everyone,
I have bought a week ago an MPU6050 (ref: Hailege 3pcs MPU-6050 MPU6050 GY-521 3 Axis Accelerometer Gyroscope Module 6 DOF 6-axis Accelerometer Gyroscope Sensor Module 16 Bit AD Converter Data Output IIC I2C for Arduino : Amazon.fr: Commerce, Industrie et Science), I am using an ESP32 and here is my setup (
My issue is that when I try to get the adress of the MPU6050 I receive the message on the Arduino IDE "No I2C devices found", here is my code:
#include <Wire.h>
  Wire.begin();
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ ) {
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address<16) {
        Serial.print("0");
      Serial.println(address,HEX);
      nDevices++;
    else if (error==4) {
      Serial.print("Unknow error at address 0x");
      if (address<16) {
        Serial.print("0");
  if (nDevices == 0) {
    Serial.println("No I2C devices found\n");
  else {
    Serial.println("done\n");
  delay(5000);
I have tried a couple of things to bypass this issue: Change the wires --> still the same issue
change de the pins, I initially used the pins 22 and 21 then I have switched to pins 15 and 16 --> still the same issue
Change the power supply started with 3.3 V and I've switched to 5V --> still the same issue
Do you have an idea of what I could do to solve this issue ?
Thank you.
You posted in the wrong section, so I have moved it here.
The section you posted in was ONLY for the Arduino ESP32 board, your photo shows this is not the case.
Pushing Dupont connector wires through the holes of the sensor board will not make reliable connections. Solder some PCB header pins.
SDA 21, SCL 22
But you need soldered pins/wiring.
Beware of the split power rails on your breadboard !
Many of your wires are in the wrong place. Move the I2C board to the middle of the breadboard and there is a Red wire at the back of the ESP32 connected to nothing.
Hello guys,
thank you for your help. I have soldered the MPU6050 to the pins.
We can clearly see on one of the image that the MPU6050 is running (green light on).
However I still cannot detect the I2C device, the error is still the same "No I2C devices found". I have also tried the code Adafruit MPU6050, it looks that I have a feedback coming out but the results are not what I expect :
7:52:56.359 -> Acceleration X: 1.22, Y: 40.58, Z: 16.55 m/s^2
17:52:56.359 -> Rotation X: -1.30, Y: -3.27, Z: 0.00 rad/s
17:52:56.359 -> Temperature: -11.56 degC.
Do you have any idea of what I could do to solve this issue ?
Thank you very much.
Post #5 showed you there was a gap in the bus bars in the bread board.
The first picture of that last post is showing that the orange wire to 5v is above the chip rather than along side it.
The reason why the LED is glowing is not proof it is working, it is a result of parasitic powering through the signal to the chip. This will light the LED but the board will not function correctly.
Hi Grumpy Mike,
Thank you for your quick answer, I confirm it looks above the chip on the picture but it is not. The wire is well aligned with the vcc pin of the MPU6050. Moreover I did not
use the 5v supply but the 3.3v. I tried the 5v supplied aswell but it did not change the result, I still not find I2C device.
Thank you.
The I2C bus requires 4.7k pullup resistors on SDA and SCL. Does that MPU6050 board already have them? If not, you need to install them.
Pete
That is odd because I don't understand how this orange wire is making contact if it is above the pin. The connecting tracks on the bread board run horizontally at this point, as seen in your photograph, not vertically. So how is it making contact even if it is aligned above it?
hello everyone,
Thank you for the idea of putting pullup resistors, I have tried. Unfortunately,
it is still not working. You can find below my setup. Do you have any Idea ?
I have tried to change the voltage aswell and nothing changed.
Thanyou.
Maybe it is clear to you but can you explain how this orange wire on the left (marked Vcc), which applies power to the MPU6050, is connected to the ESP32 ? Is there some hidden jumper for example ?
ahaha, the breadbord is not large enough therefore I had to put the VCC cable under the ESP32.
For 4 wires, do you really need breadboard? Direct wiring takes some odds out...
Sorry I still don't understand this, because I can't see the wire coming out and connecting with the row you claim it is on.
Hello everyone,
I confirm, the problem was the connection and direct wiring works. Thank you very much for your help. Now I need to calibrate my MPU6050, I let you know if I am in trouble.
Thank you.
You're welcome!
