No matching function for call to 'Pwm::attach(const byte&, int, bool)'
Hi all.
The sketch below works well on the announcer‘s wokwi.
I copied that and got compiling error of:
no matching function for call to 'Pwm::attach(const byte&, int, bool)'
how to fix?
Thanks
Adam
 // ESP32-ESP32S2-AnalogWrite
// https://github.com/Dlloydev/ESP32-ESP32S2-AnalogWrite
#include <pwmWrite.h>
const byte pwm100Hz20DutyPin = 19;
const byte pwm100Hz30DutyPin = 18;
const byte pwm100Hz50DutyPin = 5;
const byte pwm25Hz50DutyPin = 21;
Pwm pwm = Pwm();
// pwm.write(pwmPin, duty, frequency, resolution);
  pwm.write(pwm100Hz20DutyPin, 205, 100, 10);
  pwm.write(pwm100Hz30DutyPin, 307, 100, 10);
  pwm.write(pwm100Hz50DutyPin, 512, 100, 10);
  pwm.attach(pwm25Hz50DutyPin, 4, true);
  pwm.write(pwm25Hz50DutyPin, 512, 25, 10);
  delay(10); // speeds up the simulation
Arduino:1.8.19 (Windows 7), 开发板:"ESP32 Dev Module, Disabled, Disabled, Huge APP (3MB No OTA/1MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_oct12f\sketch_oct12f.ino: In function 'void setup()':
sketch_oct12f:23:39: error: no matching function for call to 'Pwm::attach(const byte&, int, bool)'
In file included from C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_oct12f\sketch_oct12f.ino:8:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\ESP32-ESP32S2-AnalogWrite-main\src/pwmWrite.h:80:13: note: candidate: 'uint8_t Pwm::attach(int)'
     uint8_t attach(int pin);                 // attach pin to next free channel
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\ESP32-ESP32S2-AnalogWrite-main\src/pwmWrite.h:80:13: note:   candidate expects 1 argument, 3 provided
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\ESP32-ESP32S2-AnalogWrite-main\src/pwmWrite.h:81:13: note: candidate: 'uint8_t Pwm::attach(int, int)'
     uint8_t attach(int pin, int ch);         // attach to specified ch
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\ESP32-ESP32S2-AnalogWrite-main\src/pwmWrite.h:81:13: note:   candidate expects 2 arguments, 3 provided
exit status 1
Seems to be complaining about the third param..
Which by looking at it, I'm thinking this would be true to invert it..
And yes, the WokWi does in fact compile fine..
Something must have changed in the lib, looking through pwmWrite.h, I'm thinking you want to use..
pwm.attachInvert(pwm25Hz50DutyPin, 4);
instead..
good luck.. ~q
Look in pwmWrite.h for the attach function:
You'll see there's no overload that includes a third parameter of type bool. So why are you supplying one?
Thanks.
Thanks.
are there any idea that ESP32 PWM be able to vary frequency or not?
