No matching function for call to 'SDClass::open(String&, int)'
Hi all.
the sketch got error at: File dataFile = SD.open(filename, FILE_WRITE);
if modified as: File dataFile = SD.open( "filename", FILE_WRITE); got compiling passed, but nothing wrote on SD card. why?
Thanks
Adam
 // Arduino code for NEO-6M + SD Card GPS Tracker
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
TinyGPS gps; // GPS initialization
SoftwareSerial ss(6, 5); // pins for GPS (D5 -> GPS RX, D6 -> GPS TX)
static void smartdelay(unsigned long ms); // delay that also takes into account GPS
bool valid_date = false; // used for naming sd file
String filename = ""; // dummy placeholder, this will be updated later based on timestamp
String prev_date = ""; // ensuring the same data points aren't saved more than once
  if (!SD.begin(chipSelect)) {
    while (1); // do nothing if SD is not started
  ss.begin(9600); // start GPS module
  float flat, flon;
  unsigned long age;
  String date_str;
  gps.f_get_position(&flat, &flon, &age);
  String datastring = "";
  date_str = find_date(gps,prev_date);
  prev_date = date_str;
  datastring+=date_str; datastring+=",";
  datastring+=String(flon,6); datastring+=",";
  datastring+=String(flat,6); datastring+=",";
  datastring+=String(gps.f_altitude(),6); datastring+=",";
  datastring+=String(gps.f_course(),2); datastring+=",";
  datastring+=String(gps.f_speed_kmph(),5);
  if (date_str=="NaN"){
    if (valid_date==false){
      valid_date = true;
      filename = filenamer(gps);
      Serial.println(filename);
      if (dataFile){
        dataFile.println("Date [mm/dd/yyyy HH:MM:SS],Longitude [deg],"
        "Latitude [deg],Altitude [m],Heading [deg],Speed [kmph]"); // alter based on data
        dataFile.close();
        Serial.println("Issue with saving header");
      // open file, write to it, then close it again
      if (dataFile) {
        Serial.print("data string: ");
        Serial.println(datastring);
        dataFile.println(datastring);
        dataFile.close();
  smartdelay(1000);
static void smartdelay(unsigned long ms) {
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
String find_date(TinyGPS &gps,String prev_date) {
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned long age;
  String date_str = "";
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    date_str = "NaN";
    int byte_size = 19;
    char chars[byte_size];
    sprintf(chars, "%02d/%02d/%02d %02d:%02d:%02d",
          month,day, year, hour, minute, second);
    for (int ii=0;ii<=byte_size-1;ii++){
      date_str+=String(chars[ii]);
  if (date_str==prev_date){
    return "NaN";
  return date_str;
String filenamer(TinyGPS &gps) {
  int year;
  unsigned long age;
  int byte_size = 8;
  sprintf(chars, "%02d%02d%02d%02d",
        day, hour, minute, second);
    filename+=String(chars[ii]);
  return filename+".csv";
ERROR:
Arduino: 1.8.19 (Windows 7), Board: "Arduino Uno"
E:\ENGINEERING\DIY\Electronic\ESP32\good\3 EYE_clock_game_Stream_health_GPS_sth\00_map\Arduino GPS Tracker\Arduino_GPS_Tracker\Arduino_GPS_Tracker.ino: In function 'void loop()':
Arduino_GPS_Tracker:55:51: error: no matching function for call to 'SDClass::open(String&, int)'
Multiple libraries were found for "SoftwareSerial.h"
 Used: C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SoftwareSerial
 Not used: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\SoftwareSerial-master
In file included from E:\ENGINEERING\DIY\Electronic\ESP32\good\3 EYE_clock_game_Stream_health_GPS_sth\00_map\Arduino GPS Tracker\Arduino_GPS_Tracker\Arduino_GPS_Tracker.ino:12:0:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\SD/SD.h:74:8: note: candidate: File SDClass::open(const char*, uint8_t)
   File open(const char *filename, uint8_t mode = FILE_READ);
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\SD/SD.h:74:8: note:   no known conversion for argument 1 from 'String' to 'const char*'
Arduino_GPS_Tracker:65:51: error: no matching function for call to 'SDClass::open(String&, int)'
exit status 1
option enabled in File -> Preferences.
