#include <SoftwareSerial.h>
#include <dht11.h>
#include <ACS712.h>
#define RX 2
#define TX 3
#define dht_apin A0 // Analog Pin sensor is connected to
dht11 dhtObject;
String AP = "Redmi"; // AP NAME
String PASS = "Sunny898"; // AP PASSWORD
String API = "ABY09QBF56MZ59QL"; // Write API KEY
String HOST = "api.thingspeak.com";
String PORT = "80";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
int valSensor = 1;
ACS712 sensor(ACS712_30A, A1);
SoftwareSerial esp8266(RX, TX);
esp8266.begin(115200);
sendCommand("AT", 5, "OK");
sendCommand("AT+RESTORE", 5, "OK");
sendCommand("AT+CWMODE=1", 5, "OK");
sendCommand("AT+CWJAP=\"" + AP + "\",\"" + PASS + "\"", 20, "OK");
sensor.calibrate();
String getData = "GET /update?api_key=" + API + "&field1=" + getTemperatureValue() + "&field2=" + getHumidityValue() + "&field3=" + getCurrentAC();
sendCommand("AT+CIPMUX=1", 5, "OK");
sendCommand("AT+CIPSTART=0,\"TCP\",\"" + HOST + "\"," + PORT, 15, "OK");
sendCommand("AT+CIPSEND=0," + String(getData.length() + 4), 4, ">");
esp8266.println(getData); delay(1500); countTrueCommand++;
sendCommand("AT+CIPCLOSE=0", 5, "OK");
String getTemperatureValue()
dhtObject.read(dht_apin);
Serial.print(" Temperature(C)= ");
int temp = dhtObject.temperature;
Serial.println(temp);
delay(50);
return String(temp);
String getHumidityValue()
Serial.print(" Humidity in %= ");
int humidity = dhtObject.humidity;
Serial.println(humidity);
delay(50);
return String(humidity);
String getCurrentAC()
float I = sensor.getCurrentAC();
Serial.print("I = ");
Serial.print(I);
delay(50);
return String(getCurrentAC);//Errror in this line
void sendCommand(String command, int maxTime, char readReplay[])
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while (countTimeCommand < (maxTime * 1))
esp8266.println(command);//at+cipsend
if (esp8266.find(readReplay)) //ok
found = true;
countTimeCommand++;
if (found == true)
Serial.println("Ok");
countTrueCommand++;
countTimeCommand = 0;
if (found == false)
Serial.println("Fail");
countTrueCommand = 0;
found = false;
How yo fix this???
