No Method of No USB uploading Works!
Hi, I have 2 Arduinos With bad USB ports, 2 Mega 2560 Pros.. No method of uploading without USB works, I tried CH340 USB to Serial, FT232RL USB to Serial, Arduino as ISP with a regular Nano (328p with FTDI not CH340 onboard USB) and a ProMicro (ATMEGA32U4), and a USBasp (Using libusb-win32 driver installed with Zadig). Each time I get different results so I will divide into 2 Sections:
1- Broken Megapro 1
2-Broken Megapro 2 (Has the onboard CH340 chip desoldered and removed completely)
1:
Broken Mega 1:
  • With USBasp
    I connect using a 10 pin to 6 pin converter to icsp header and try to upload blink, what i get with verbose upload enabled:
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\20106\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 0
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Failed programming: uploading error: exit status 1```
*With FT232RL
```type or paste code here```
* With Nano As ISP
* With CH340
```avrdude: Version 6.3-20190619
         Using Port                    : COM18
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
Failed uploading: uploading error: exit status 1```
* With ProMicro as ISP
         Using Port                    : COM14
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0xffffff (probably .avr8x_mega) (retrying)
avrdude: Yikes!  Invalid device signature.
         this check.
2:
Broken Mega 2:
* With USBasp
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         this check.
*With FT232RL
`will add`
* With Nano As ISP
* With CH340
         Using Port                    : COM18
         Using Port                    : COM14
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
         this check.
Thanks to anyone who took the time, I only need 1 method to work so please help
Will add all other outputs shortly
Hi @youssefshaalan.
This error is caused by using the "libusb-win32" driver with Arduino's version of AVRDUDE:
The solution is to use the libusbK driver instead:
  1. Download the "Zadig" driver installation tool from this website:
    http://zadig.akeo.ie/
    ⓘ Zadig is recommended on the official USBasp website: http://www.fischl.de/usbasp/
  2. Plug your USBasp into your computer.
  3. Start "Zadig".
  4. From the dropdown menu in the "Zadig" window, select "USBasp".
    :red_exclamation_mark: If it doesn't show up on the menu, then select Options > List all devices from the Zadig menus and check again.
  5. Click the up or down arrows next to the Driver selection box on the right side until you see "libusbK".
  6. Click the "Replace Driver" button.
  7. Wait for the driver replacement process to finish.
  8. Close the "Zadig" window.
Now try using the USBasp programmer once more. Hopefully the error will no longer occur.
@ptillisch Now it works but the mega never runs the code even tho it says done uploading, tried resseting and powering directly :frowning:
It is likely caused by the problem discussed here:
The community created an alternative version of the USBasp firmware that has a fix for that problem:
how do i update firmware without another asp?
You must have another ISP programmer to do it.
If you don't have a second dedicated programmer, you can make a DIY "Arduino as ISP" programmer from an Arduino board:
https://docs.arduino.cc/built-in-examples/arduino-isp/ArduinoISP/
You can connect that "Arduino as ISP" programmer to the USBasp programmer and then update the USBasp firmware.
