No port available for Arduino uno on Linux
A visual inspections goes far. I've seen pins that where totally missing, bent, or just dirty.
Just ran
udo apt-get remove brltty
Use 'sudo apt autoremove' to remove them.
0 to upgrade, 0 to newly install, 0 to remove and 12 not to upgrade.
Auto remove was going to remove
linux-headers-5.15.0-122 linux-headers-5.15.0-122-generic
linux-headers-5.15.0-124 linux-headers-5.15.0-124-generic
and more, so I chose not to yet.
I'm getting a little confused.
You have two boards; are both not showing up in the IDE and giving the same results in dmesg?
I think that this is your problem.
This is probably the most promising one to solve your problem: usb - modemmanager conflicts with arduino - Ask Ubuntu
Below (for reference) the output of my arduino . org Uno (hence the idVendor is different). Ubuntu 24.04.
[  363.345217] usb 1-3.4.3: new full-speed USB device number 13 using xhci_hcd
[  363.424540] usb 1-3.4.3: New USB device found, idVendor=2a03, idProduct=0043, bcdDevice= 0.01
[  363.424576] usb 1-3.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[  363.424589] usb 1-3.4.3: Product: Arduino Uno
[  363.424599] usb 1-3.4.3: Manufacturer: Arduino Srl
[  363.424607] usb 1-3.4.3: SerialNumber: 75439333235351119142
[  363.435372] cdc_acm 1-3.4.3:1.0: ttyACM3: USB ACM device
Note
BRLTTY would show up in dmesg output.
Yes I agree, I would have thought BRLTTY would but it doesn't.
Now with no Arduino's connected to my computer, it is listed in
dmesg | tail -f
but then shows as disconnected.
Anyway I'll have a read of the page you linked. However the OP did not resolve his problem by the answers given, but I'll still try myself.
Thanks
You are the OP. What am I missing?
The original poster, commonly referred to a OP
But you started this topic so you are the OP.
If you are referring to BRLTTY then you could try
Thanks but using this command line:
grep ea60 /lib/udev/rules.d/85-brltty.rules
grep: /lib/udev/rules.d/85-brltty.rules: No such file or directory
@sterretje,
yes I did but I meant the poster in the link , although there is no name for him.
@avalon66 and @sterretje
To point you in the right direction: The device disconnect. @sterretje said something about lsusb, and whatever the driver status is, the device should still be listed with lsusb.
Yes, sometime it is but others it it is not , like now even when I plug the arduino in.
Anyway, I'll wait until the new cable arrives, and take from there
My new cable arrived and I connected it to the 1st Arduino Uno I tried yesterday, and it seen right away by the IDE on port ttyACM0.
So after all that , it was or is a duff data cable.
Thanks again all who replied to my problem.
