"No Ports Discovered" on xubuntu with IDE 2.2.1
I have just returned to doing some Arduino programming. I have installed the 2.2.1 IDE on my xubuntu 22.04 system and I'm getting 'NO PORTS DISCOVERED' whatever I try.
I have connected both an ESP32 based system and a Raspberry Pi with the same result for both.
When I plug the ESP32 device in I see:-
Nov 23 11:12:03 esprimo kernel: [1472081.626400] usb 2-1.5: new full-speed USB device number 23 using ehci-pci
Nov 23 11:12:03 esprimo kernel: [1472081.735794] usb 2-1.5: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice=81.34
Nov 23 11:12:03 esprimo kernel: [1472081.735804] usb 2-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Nov 23 11:12:03 esprimo kernel: [1472081.735808] usb 2-1.5: Product: USB Serial
Nov 23 11:12:03 esprimo kernel: [1472081.736824] ch341 2-1.5:1.0: ch341-uart converter detected
Nov 23 11:12:03 esprimo kernel: [1472081.738106] usb 2-1.5: ch341-uart converter now attached to ttyUSB0
Nov 23 11:12:03 esprimo mtp-probe: checking bus 2, device 23: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5"
Nov 23 11:12:03 esprimo mtp-probe: bus: 2, device: 23 was not an MTP device
Nov 23 11:12:03 esprimo systemd[1]: Starting Braille Device Support...
Nov 23 11:12:03 esprimo brltty[2960433]: BRLTTY 6.4 rev BRLTTY-6.4 [https://brltty.app/]
Nov 23 11:12:03 esprimo brltty[2960433]: executing as the invoking user: root
Nov 23 11:12:03 esprimo brltty[2960433]: brltty: executing as the invoking user: root
Nov 23 11:12:03 esprimo Thunar[2960432]: thunar-volman: Unsupported USB device type "usb".
Nov 23 11:12:03 esprimo Thunar[2960459]: thunar-volman: Unsupported USB device type "ch341".
Nov 23 11:12:04 esprimo brltty[2960433]: CLDR open error: No such file or directory: /usr/share/unicode/cldr/common/annotations/en.xml
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: CLDR open error: No such file or directory: /usr/share/unicode/cldr/common/annotations/en.xml
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: possible cause: the package that defines the CLDR annotations directory is not installed
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: emoji substitutiion won't be performed
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: BrlAPI Server: release 0.8.3
Nov 23 11:12:04 esprimo brltty[2960433]: possible cause: the package that defines the CLDR annotations directory is not installed
Nov 23 11:12:04 esprimo systemd[1]: Started Braille Device Support.
Nov 23 11:12:04 esprimo brltty[2960433]: emoji substitutiion won't be performed
Nov 23 11:12:04 esprimo brltty[2960433]: BrlAPI Server: release 0.8.3
Nov 23 11:12:04 esprimo brltty[2960433]: Linux Screen Driver:
Nov 23 11:12:04 esprimo kernel: [1472082.309734] input: BRLTTY 6.4 Linux Screen Driver Keyboard as /devices/virtual/input/input33
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: Linux Screen Driver:
Nov 23 11:12:04 esprimo brltty[2960433]: USB configuration set error 16: Device or resource busy
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: USB configuration set error 16: Device or resource busy
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: USB interface in use: 0 (ch341)
Nov 23 11:12:04 esprimo brltty[2960433]: USB interface in use: 0 (ch341)
Nov 23 11:12:04 esprimo kernel: [1472082.403751] usb 2-1.5: usbfs: interface 0 claimed by ch341 while 'brltty' sets config #1
Nov 23 11:12:04 esprimo kernel: [1472082.404143] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
Nov 23 11:12:04 esprimo kernel: [1472082.404160] ch341 2-1.5:1.0: device disconnected
Nov 23 11:12:04 esprimo ModemManager[829]: <info>  [base-manager] port ttyUSB0 released by device '/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5'
Nov 23 11:12:04 esprimo ModemManager[829]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5': Operation was cancelled
Nov 23 11:12:04 esprimo brltty[2960433]: NoSpeech Speech Driver:
Nov 23 11:12:04 esprimo brltty[2960433]: brltty: NoSpeech Speech Driver:
My system thinks it's a braille device!
How can I fix this?
I have just tried my very old Arduino Uno on the same USB port in my computer, that works fine. So my issue is with getting the ESP32 device recognised (also with the Raspberry Pi Pico).
Any advice would be very welcome.
Here is a link on how to disable/uninstall BRLTTY, [SOLVED] Tools > Serial Port greyed out in ubuntu 22.04 LTS - #16 by btaiii.
The link should work and contains instructions on how to do the uninstall/disable process, any problems and we should be able to help you.
Thanks.
