No readinging recived
 * IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
 * An IR detector/demodulator must be connected to the input RECV_PIN.
 * Version 0.1 July, 2009
 * Copyright 2009 Ken Shirriff
 * http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    Serial.println(results.value);
    if (results.value == 0xFF00FF)
      Serial.println("!");
    irrecv.resume(); // Receive the next value
hi , there no error in code but no reading i get
this wierd thing appear . what should i do?
The baudrate in the sketch and in the serial monitor shoukd match.
Your question became part of the code. I've fixed it for you. Please pay attention next time.
hi ,sorry but i dont understand how boundeate and serial monitor are different
In your code, you are setting the serial baud rate to 115200.
However, the serial monitor is set to 250000. Both numbers must match.
