NodeMCU amica to LoRa V2
hello guys !
I am working on an ESP8255 (NodeMCU Amica) to make it connect to my ESP32 (LoRa V2)
I am pretty new in the arduino world and it's the first time i am trying something with wifi modules.
My question is does anyone know how i can make them communicate directly (without a router)?
the Amica would be the master and the LoRa a slave. All the commande would be in int.
Thanks a lot for your responses !
the amica : https://fr.aliexpress.com/item/868-MHz-915-MHz-LoRa-ESP32-Oled-Wifi-SX1276-Module-IOT-avec-Antenne-Pour-Arduino-lectronique/32836246848.html?spm=a2g0s.9042311.0.0.38fb6c37FP6n3i
the nodeMCU : V3 module sans fil NodeMcu 4 M octets Lua WIFI carte de développement de l'internet des objets basée sur ESP8266 esp 12e pour Compatible arduino | AliExpress
So, the Amica won't actually be connecting to the LoRa.
If you can make the Amica an Access Point, the LoRa can connect to it.
but doesn't it mean that i will need a router ?
i don't realy see how i can make the amica as an access point.
What role would the router serve?
Then, I guess you will need a wireless router that can create an access point (as in a point of access to a network).
PaulS:
during my research i found out that to connect two wifi module you have to pass by a router.
but what i would like to do is making them communicate directly (since it would be used outside)
You need an access pointer. A wireless router creates an access point. Some ESP devices can create access points. If the Amica can't, find a different one that can.
okey thanks
