it shows zero values unless replug connecting wire between nodemcu and sensor,
Posted in the wrong place. I moved it here. Try and be more careful where you post in future.
That's normal without pullup resistors on SCL and SDA. Add resistors to the pins if you want to use I2C without pullup resistors on other devices.
