I am using nokia 5110 lcd, with arduino uno r3 & v1.6.5
I have below libs & they worked both fine:
Arduino Playground - PCD8544
Downloads | Nokia 5110/3310 Monochrome LCD | Adafruit Learning System -
Currenly I am using first library.
Now MCu works at 5V while lcd is at 3.3V. So I need a level translator.
However instead of shifting level, I have connected 10K series resistor at reset, cs,dc din, & clk pins.
is it ok to do so or I need to connect a level translator. -
Vdd lcd = 3.3V via arduino board.
5K pot at BL pin of lcd, for adjustment.
Vindchal_Takniki:
4. Now MCu works at 5V while lcd is at 3.3V. So I need a level translator.
You don't need a level translator, you can run the LCD off the Arduino 3.3v pin. There is no need to do anything with resistors. I don't know what you mean by Vdd, but a pot is getting a bit precious with these displays. A 680r should suffice if you really need a light but you might not. If the display has a blue backlight, and you have some ambient light, you are likely to read it better with the backlight disconnected. Note that some 5110s activate the light by grounding the pin.
thx
