Non_class Type?
OK, I have striped the program down to this, with no resolution.
#Includes
#include <Arduino.h>
#include "Water_Level.h"
// #include "Switches.h"
clSwitches CLASS
Handles the presses of the switches
enum eSwitch_ST {
SW_Init_ST = 0,
SW_WaitingForNotPressed_ST,
SW_NotPressed_ST,
SW_Pressed_ST
class clOffsetSwitch
public:
eSwitch_ST Switch_ST;
ULONG Switch_HoldTime;
    clOffsetSwitch();
    void        Run( void );
Globals
bool OffsetSwitchWasPressed;
Library functions
#includes
clOffsetSwitch CLASS
Handles the presses of the buttons
clOffsetSwitch::clOffsetSwitch( ) {
Switch_ST = SW_Init_ST;
Handles the running the buttons
void clOffsetSwitch::Run( void ) {
switch ( Switch_ST ) {
case SW_Init_ST:
    case  SW_WaitingForNotPressed_ST:
    case  SW_NotPressed_ST:
    case  SW_Pressed_ST:
    default:
        // Switch_ST = SW_Init_ST;
Global Variables
clOffsetSwitch OffsetCalSwitch();
setup() function
Things done at startup
loop() function
Things done continuously, over and over
OffsetCalSwitch.Run();
And an .H file of:
#Includes
clSwitches CLASS
enum eSwitch_ST {
SW_Init_ST = 0,
SW_NotPressed_ST,
SW_Pressed_ST
public:
    clOffsetSwitch();
    void        Run( void );
Globals
Library functions
#includes
case SW_Init_ST:
    case  SW_Pressed_ST:
    default:
Global Variables
setup() function
loop() function
I am getting an error message:
0_01\Water_Level_R0_01\Water_Level_R0_01.ino: In function 'void loop()':
C:\Users\jacks\OneDrive\ERG\Water Level\Design\Software\Rev 0_01\Water_Level_R0_01\Water_Level_R0_01.ino:112:21: error: request for member 'Run' in 'OffsetCalSwitch', which is of non-class type 'clOffsetSwitch()'
exit status 1
Compilation error: request for member 'Run' in 'OffsetCalSwitch', which is of non-class type 'clOffsetSwitch()'
Obviously, the project is much bigger, but this fails for me.
Do you get the same?
What am I doing wrong?
try this
clOffsetSwitch OffsetCalSwitch;
If the constructor has no arguments, the object must be initialized without empty brackets after the name
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
OMG! WTF! That did it!
40 Years of OOP programming, and I never had to do that!
Thanks!
Originally, I had two switch pins.
So I made a generic function to handle both.
Obviously, with a change in the pin_number. That's where my problems started.
How should I do the constructor to accept the "Pin Number"?
It's not solved till it's resolved!
So, how do we do a Constructor with a parameter passed?
